best way to remove rad support
i am in the process of removing my rad support on my 67 and i was just wondering what the best way to do it is without taking off the front fenders or front grille. Also, do you know why i cant search anything. it says that i dont have permission everytime i try.
67pro-street |
Search is disabled. No one can do it.
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
ok, thanks tyger. i was starting to get a little mad.
LOL....I feel kinda dumb when I ask a question, cause I don't know if it's been covered before, or if it has been repeated over and over. I'm sure that repedative questions can get old.
Low & Slow
From what I know, you have to take the front clip apart to get the rad. support out. That's probably not what you wanted to hear but..... I don't see it being possible without doing it.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
![]() Join Date: Feb 2002
Yup. Or at least the hood and one fender. The ends of the radiator core are locked into pockets built into the fenders. I guess you'd have to pull the grill too.
1969 Custom 30 wrecker
I was able to do it with my 69 but not sure on a 67. The fenders will have some give to move side to side once the support is unbolted from them. I had the grill assembly on mine too.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Hammer On!
![]() Join Date: Jul 2001
Rad Support
I removed a donor rad support off a salvage 67 about 6 months ago. It took some time to get that thing out but i had to remove the front grille, hood latch and of course the endless amounts of bolts! The fenders stayed on and the hood was also left alone. I hope this helps and good luck with it!
Aaron ![]()
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
ok thanks fellas. i guess it will just take longer than i expected.
