07-27-2015, 12:57 PM | #1 |
axle length
I have a friend who has a 51 Chevy truck with a 55 Chevy car rear end in it.
It has an open carrier but has axles from a rear with a posi. He thinks the axles are different lengths from an open to a posi rear. I say they're the same length. Who's right? He's got a seal leaking and thinks the axle length has something to do with that. Thanks in advance for any responses. |
07-27-2015, 02:33 PM | #2 |
Re: axle length
The posi axles will be shorter
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-27-2015, 04:00 PM | #3 |
Re: axle length
Posi axles are shorter, however only by 1/8". You can easily grind of a 3/32-1/8" per shaft and it will work fine.
55.1 GMC Suburban Hydramatic |
07-27-2015, 04:58 PM | #4 |
Re: axle length
Thanks for answering my question. Now on to the next one.
Should there be an axle seal installed in the housing ahead of the axle bearing? Rock Auto as well as NAPA show one along with the o ring that goes on the outer race of the bearing. If the bearing is greased before installation, it shouldn't need lubed from the rear end lube, correct? If the new bearing is a sealed unit it wouldn't need any more lube in my estimation and if an older style ball bearing is used the bearing grease would be sufficient. |
