Old 07-27-2015, 06:44 PM   #1
cjoenny89
cjoenny89's Avatar
68 C20 2wd front shock lower bolts
I am changing the front shocks on my c20 2wd I think you guys are getting to know me too well. Finally got the top bolts out and the right studs but went to install new bolts on the bottom and when you push the bolt though the nut won't fit in. I thougjt the old nuts were just corded from sitting all these years but no looks like the only way the nuts fit on is to grind the bottom half off to fit? Is this common or what happen along the way? Keep in mind this truck was parked from 1985 on until I have been working onit. Here is a picture. What do I need to do for the bottom shock bolt?
cjoenny89 is offline   Reply With Quote
Old 07-27-2015, 07:23 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 68 C20 2wd front shock lower bolts
I just replaced the bolts on my '67 and the full sized nuts fit OK. I had to put the nut down in the pocket and then screw the bolt into it. Are you sure the tabs aren't bent in toward the lower "A" arms a little? One of mine was and I had to put a bar in behind it and bend it out a little bit.....
LockDoc
Leon
