Old 09-07-2003, 11:23 PM   #1
chevyforever
Some like em' long!
Lightbulb coil rear lowering concerns
i am about to lower the rear of my 71 half ton with coils. i believe the previous owner heated up the coils to lower it somewhat because the springs look funny compared to normal ones. the thing that i am wondering about, is when you put in the lowering springs, it will move the rear differential to the passenger side and make it not centered with the rest of the truck,,right? because of the traction bar. can you just shorten the bar, or do they have an aftermarket one to go with the springs. thanks for any lignt on this situation.
chevyforever
1971 chevy c10 lwb- 300 hp 350 crate motor, soon to be more with ported and polished 62cc chamber 461 double humps, TH400, 3.73 posi, used to be my uncle's truck
1972 chevy k10 lwb- 350,4 spd, old and tired, dad bought brand new and is now mine
1968 chevy c20 lwb- 327, 4 spd, was originally a 50th anniversary truck
1990 GMC K1500-just my runaround truck
1982 Chevy K10 shortbed, new motor and new paint, another project in the mix of the others.
IMPORTS SUCK!
chevyforever is offline   Reply With Quote
Old 09-07-2003, 11:39 PM   #2
70 longbed
You can purchase an adjustable panhard bar. I bought mine from Early Classics Enterprise.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 09-07-2003, 11:41 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Also, the springs are supposed to be like that. The center 3 coils are almost touching...right?
They are a variable rate spring. (onless you have H.D. springs, then they should be evenly spaced.)
Old 09-08-2003, 12:17 AM   #4
BraveDave
i have 4-inch lowering springs on my truck and there is no significant difference at all. if you are going lower than that, you may encounter a problem, in which case an adjustable panhard rod will fix you up!
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Old 09-08-2003, 12:26 AM   #5
Longhorn Man
Brave dave, how wide are your rims, and how much back spacing do you have?
A 4 inch drop with the stock bar seems a bit exsesive to me. I can load down my truck with stock springs, drop it 4 inches with the weight, and have lots of rubbing. (I have shiney metal in my wheel wells).
You need to keep in mind the variables. Stock sized wheels and tires would pass with a 4 inch, real wide stiff would shred on the sheet metal.
Old 09-08-2003, 02:33 AM   #6
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I'm with andy on this one, I have 4" drop springs and the early classic adjustable track bar isn't enough to pull the rear over dead center in the frame. My guess is my worn out trailing arm bushings.... I've had a pair of poly bushings setting on my desk for over 6 months. I'll be installing them soon though.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-08-2003, 08:31 AM   #7
MOTHERTRUCKERS
How much adjustment is in the early classics track arm?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-08-2003, 11:15 PM   #8
Longhorn Man
Hmmm, good question mothertruckers.
Anyone able to answer?
Old 09-08-2003, 11:39 PM   #9
Hugger
Hugger's Avatar
I havn't adjusted mine yet, but looks to be at least 3" to 4"
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 09-08-2003, 11:43 PM   #10
Hotrod70C10
Low & Slow
I can't remember it's been on my truck since the first of the year.
4.5/6 drop
Old 09-09-2003, 10:48 AM   #11
MOTHERTRUCKERS
Thanks.
Old 09-09-2003, 11:37 AM   #12
MrShelley
Too Many Clubs Club
MrShelley's Avatar
The Early Classic Super Track Bar Kit has nowhere NEAR 3" to 4" of adjustment. Mine isn't installed yet, so I'll measure how much it does have when I get home.
MrShelley is offline   Reply With Quote
Old 09-09-2003, 08:13 PM   #13
Red68
Red68's Avatar
I lowered my 68 4" and used an adjustable bar, I probably only changed the length by 1/2" or so. Not much difference as far as I could tell.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-09-2003, 08:59 PM   #14
Hotrod70C10
Low & Slow
Red68, I had that same problem..... No i'm going to drop the rear more than 4" and I'm going to have to go ahead and buy the whole kit with the longer bar..... If I could only keep my mind made up for once....
4.5/6 drop
