Old 07-29-2015, 09:28 AM   #1
lowlyfec10
trans shift linkage
how many aftermarket options are there if you are using the 4l80e with NSS? need to order something to get that part of the swap checked off the list...
lowlyfec10 is offline   Reply With Quote
Old 07-29-2015, 11:55 AM   #2
dayj1
Re: trans shift linkage
I like the Lokar rod-style linkage and I don't recommend the cable style.
dayj1 is offline   Reply With Quote
Old 07-29-2015, 05:43 PM   #3
toddoky
x 2 on using the Lokar, or similar, rod style linkage for your 4L80.
toddoky is offline   Reply With Quote
Old 07-30-2015, 02:51 AM   #4
josueh95
http://www.shiftworks.com/kugel.htm#kit
used this one on mine, lots of room for adjustments and works great
josueh95 is offline   Reply With Quote
Old 07-30-2015, 09:38 AM   #5
lowlyfec10
did you use the 4le fix it kit?? looking at the pix between the 2 it seems they flipped the bracket and maybe use a diff style end?
