Old 07-29-2015, 03:33 PM   #1
willem445
willem445's Avatar
Bypassing the heater core?
Hi guys,
At some point in time either my dad or grandpa decided to bypass the heater core. Im sure the heater core leaked or didnt work or something like that. I just want to bypass it for now until I get time to fix the heater core (not in any rush at all). The current bypass job is pathetic and leaks. I tried taking a small piece of hose and directly connecting the inlet and outlet but its a very awkward angle and the hose kinks slightly. Any idea what the best way to do this would be?
I attached some pictures to give a decent idea of what im talking about.
Also what are the sizes of the two different hoses so I can get replacement hose?
willem445 is offline   Reply With Quote
Old 07-29-2015, 04:09 PM   #2
rich weyand
rich weyand's Avatar
Re: Bypassing the heater core?
5/8" and 3/4" heater hose. Those are inside diameter numbers (ID).
You will also need a 3/4" Barb x 5/8" Barb Reducing Coupling (on this page, for example: https://www.plumbingsupply.com/barb.html) and some band clamps.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 07-29-2015, 04:17 PM   #3
willem445
willem445's Avatar
Thanks for reply.
Are the threads on the barbs also 3/4" and 5/8"? Thinking about getting some angled ones to make the angle easier to deal with.
Old 07-29-2015, 04:52 PM   #4
rich weyand
There are no threads on a reducing hose adapter. It is one hose size on one end, the other hose size on the other.
Rich Weyand
1978 K10 RCSB DD.
Old 07-29-2015, 04:55 PM   #5
willem445
willem445's Avatar
Im talking about replacing the actual inlet and outlet barbs on the block to a 45degree so I can just use a short piece of hose that doesnt kink. Im not sure what size the threads are that actually screw into the block. I will pick up one of the reducing couplers to avoid leaks.
Old 07-29-2015, 06:03 PM   #6
mrolds88
If you are going to replace the end fittings for a temporary thing, why not put in plugs and not worry about the hose?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-29-2015, 07:51 PM   #7
nonstop
Plugs sound like the cleanest and best bet!
nonstop is offline   Reply With Quote
Old 07-29-2015, 09:37 PM   #8
tucsonjwt
x 2 on plugs. I got 2 brass plugs in the PEX aisle at Home Depot when I bypassed a heater core. You can leave the heater core nipples open or cover them with some aluminized tape or any kind of tape. Or, you can use a hose designed for bypass with two nipples or lengths of tubing.
Amazon.com: Gates 18701 Molded Heater Hose:... Amazon.com: Gates 18701 Molded Heater Hose:...
tucsonjwt is offline   Reply With Quote
Old 07-30-2015, 03:33 AM   #9
LuckyLightning
LuckyLightning's Avatar
Funny, we were just talking about this in another thread. The PEX valve works great, no leaks. About $10 from Home Depot. Buy two hose clamps too. I like this better because you can turn it on or off when you want, but if you never really want to run the heater core then the bypass hose is great because then you're still getting fluid circulated to your intake (although it does not seem to damage anything when using the valve to shut off the fluid altogether).
Michael
- 1962 C20 LB stepside (project thread) - sold
- 1963 Chevy C10 LB stepside (donor)
- 1963 Chevy C10 LB Custom flatbed (project thread) - sold
- 1979 K20 LB fleetside (project thread)
Favorite exchange on the board so far:
ol_Curt: "Jason, do you have power steering?"
jason65: "No, but I lift weights."
LuckyLightning is offline   Reply With Quote
Old 07-30-2015, 08:42 AM   #10
willem445
willem445's Avatar
I was actually curious about this. You can simply just plug the holes and the coolant will still flow properly? Still raises the question of what size the holes are to by the correct fitting threads for plugs. Thanks.
Old 07-30-2015, 08:44 AM   #11
willem445
willem445's Avatar
Amazon.com: Gates 18701 Molded Heater Hose: Automotive
http://www.homedepot.com/b/Plumbing-...s/N-5yc1vZbuvt
Something like this i would assume? What size did you buy?
Old 07-30-2015, 03:47 PM   #12
tucsonjwt
I used PEX shark bite brass test plugs when I bypassed the heater core on my CAV. I see 1/2" and 3/4", so I would try 3/4" on both the 5/8" and 3/4" line. I would bring calipers with me to HD and measure the OD on the plugs to be sure. I think the 5/8" line will stretch enough to accommodate a 3/4" plug, but check first to be sure.
http://www.homedepot.com/p/SharkBite...8LFA/202270641
Old 07-30-2015, 03:53 PM   #13
willem445
willem445's Avatar
Oh you just pluged the hose, not the actual block? This still seems like a good solution. Ill be stopping at Home Depot tonight to find some plugs.
Old 07-30-2015, 04:09 PM   #14
tucsonjwt
Actually, I used the plugs on two short hoses coming from the heater core on the Caviler. Those short hoses connected to metal connections on top of the engine, so I installed the bypass hose on the metal connections. The plugs are not necessary if you are totally disconnecting the heater core. If you are just going to unhook the two heater hoses at the heater core and plug them at that point you can use two plugs, but I would use a bypass hose and loop the two hoses together with two nipples.
You would tape off or cap the heater core nipples if you did not want insects or other critters to get inside your heater core.
As a practical matter, if your heater core is bad you should just install an new heater core - maybe $25 at a parts store -preferably copper/brass. Installation requires removing the dash pad and box + cables and hoses under the dash but probably doable in 2-3 hours even without experience.
Old 07-30-2015, 04:15 PM   #15
willem445
willem445's Avatar
Yeah that makes sense. The heater core has been completely disconnected for about 10 years now but the connections to the heater core were duct taped off thankfully. Eventually I will get around to replacing the heater core but right now it is not a priority, I just want to get it street legal for the time being. Just looking for a cheap solution now that doesn't look horrible. Ive gotten pretty good at tearing apart my truck so replacing the core shouldnt be all that hard.
Thanks for the help guys! Ill try and post some pics of my solution when I get time to go home and work on the truck.
