07-29-2015, 05:19 PM | #1 |
TH350 NP205 Adapter Sleeve Coupler
Looking for some help on my 1972 K10, 350, TH350, NP205 Adapter. I want to get a new bearing and sleeve in the adapter but they seem hard to come by for older style. Can I use a newer style sleeve without the bearing and just have it float on seals? Trying to find another solution if unable to find original style bearing and sleeve.
07-29-2015, 08:27 PM | #2 |
Re: TH350 NP205 Adapter Sleeve Coupler
The replacement couplers eliminate the bearing in the adapter (no you don't need it in there). I replaced mine (TH350/NP205) and took the bearing out, put new seals in and has been fine for 5 years. Typically when the trans fluid leaks into the transfer case you need new seals. Here is a picture of my old adapter and the removed bearing. See the link below for a typical new adapter shaft without a land for the bearing.
http://www.cmgearworks.com/transfer-...0r4-automatic/
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
07-30-2015, 12:06 AM | #3 |
That is good to hear, I was concerned the adapter bearing setup was required for alignment and sealing. Thanks
01-02-2017, 03:21 PM | #4 |
K5drive
I have this nos coupler never installed. Purchased it on line anticipating the need for it but never did have the need to change it
01-02-2017, 03:24 PM | #5 |
K5drive
Np205 350th
01-02-2017, 03:27 PM | #6 |
K5drive
27 splines NOS has been sitting on shelf when I purchased from eBay ten years ago . I paid $65 plus shipping then .will offer same today
01-02-2017, 03:30 PM | #7 |
K5drive
