07-29-2015, 07:06 PM | #1 |
driveshaft
I want to put the powerglide automatic transmission out of my 66 donor truck (c-20) in my 66 c-10 shortbed. I need to find a driveshaft that will fit. Any ideas? Both trucks have driveshafts in them now. Both trucks are inline 6
07-29-2015, 07:43 PM | #2 |
Re: driveshaft
is the p/glide in good shape
ron |
07-29-2015, 08:16 PM | #3 |
Re: driveshaft
if the shortbed has a three speed it might be the one ya need.
07-30-2015, 06:22 AM | #4 |
07-30-2015, 06:23 AM | #5 |
07-30-2015, 06:26 AM | #6 |
07-31-2015, 12:09 AM | #7 |
60-66 Nut
Re: driveshaft
If the Powerglide needs rebuilt, I wouldn't waste my money on one. Putting your money into a TH350 would be money better spent IMO. In fact a TH350 may even cost less. A TH350 will make your truck nicer to drive than with a Powerglide.
07-31-2015, 01:20 AM | #8 |
1961 crewcab
Re: driveshaft
I think the pg we rebuilt for my dads 55 chevy was about $900, and it still doesn't work right... wish he had gone wit the th350 like he originally planned, or even the standard 3 speed.
I think the 3 speed and pg use the same length drive shaft. I put a th350 in my long box 63 (2 piece driveshaft) and I used the front driveshaft out of a 3 speed long box. your short box might have a 1 piece drive shaft? my 61 short step with a 3 speed manual has a 1 piece driveshaft however my 64 suburban with a 3 speed manual (same wheelbase) had a 2 piece, and it also had the light duty center bearing. I would do some measuring, and check out the yoke , pg compared to the manual, if they are different , that might be the only piece you need to change.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-31-2015, 11:53 AM | #9 |
07-31-2015, 11:54 AM | #10 |
Re: driveshaft
And that will hook up to the 6 cylinder engine?
Posted via Mobile Device |
07-31-2015, 01:21 PM | #11 | |
Re: driveshaft
if you are going to rebuild, you may as well spend it on the newest and most efficient for your truck that doesn't require a computer. ron |
08-01-2015, 01:29 AM | #12 |
60-66 Nut
Re: driveshaft
Yes. The 230/250 and 292 I6 engines have the same bellhousing bolt pattern as all small blocks, all big blocks and 90 degree V6's.
I thought about recommending the 700R4, but those are a little spendy to have built right and then you have to figure out how to mount and correctly adjust the TV cable. To my knowledge no one makes a TV cable/bracket kit for the I6 unless you are running a 4 barrel carb.
08-01-2015, 10:01 AM | #13 |
Post Whore
Re: driveshaft
T5 5 speed is a common 6 cylinder swap and I believe you need to have you driveshaft shortened for that. I'd do the auto, or a t5. Personally I like shifting my own gears so I picked a tko600 for my 292 build.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
