![]() Join Date: Nov 2013
Hickey fuel tank washer nuts
I have a customer doing a very correct Hickey build and he needed these made so I made a few extras. These are the washer nuts for the extra large tanks. 2" OD with 3/8" square drive center hole and 2 3/16" holes. I weld a 1.5" long sleeve nut to the back side just like the originals. Just wondering if anyone else needs one.
Re: Hickey fuel tank washer nuts
This is what the originals look like.
Carpe manana
![]() ![]() Join Date: Dec 2010
Erik I believe these were also used for both factory accessory aux fuel tanks for 71-72 pickups as well as the similar dealer/aftermarket aux tanks. Posting an add to the pickup board may yield additional takers. Best, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Member #1049
Pete, I do believe you are correct, and used ones very rarely come off in one piece if all all
Thanks Pete. I'll get a post going their too. Out of 16 I've only pull one out complete. On the new ones the sleeve nut OD is just a bit smaller to prevent rust weld. Also anti seize would be wise.
All about them K’s
![]() Join Date: Jun 2014
How much are you asking for them?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
I'll be posting an add soon price ESTIMATE is $20 each or $70 for a set of 4.
How did you form those washers? Blank was probably cut with laser or water, but just wondering how you got the dome shape to it.
Dan |
They are first laser cut then formed with a pressing die with the knockout rod removed.
Thanks !! I thought maybe you had a different method so that a die wouldn't have to be made for such a small production run. They look great.
Dan |
I have an ever growing collection of simple dies. Perfect for projects like these.
