Old 07-30-2015, 10:25 PM   #1
Steven R
Sorry need help ID this rear end
I have this 3/4 ton frame I just picked up for some other parts and I am told that this rear end is a high speed rear end. It is of no use to me as i have a leaf spring dana 60 in my truck. Just want to give a accurate description of what I am planning to sell. I can not find a 60 number on this axle. I am assuming that this is a dana 60 for a spring setup and mine is a dana 60 for a leaf setup.
Thanks for you help and time.
Pic 1 2 3 4 are the axle in question
the last pic is my truck a dana 60 leaf setup
Steven R is offline   Reply With Quote
Old 07-30-2015, 11:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sorry need help ID this rear end
Should be a number cast into the web of the center section just below and to the right of the fill plug. (where all of the grease is)
To determine the ratio you might check this thread out.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
Posts #8 & 19 show where the code number stampings might be located.....
LockDoc
Leon
Old 07-31-2015, 11:53 AM   #3
Taibo
Originally Posted by Steven R View Post
I have this 3/4 ton frame I just picked up for some other parts and I am told that this rear end is a high speed rear end. It is of no use to me as i have a leaf spring dana 60 in my truck. Just want to give a accurate description of what I am planning to sell. I can not find a 60 number on this axle. I am assuming that this is a dana 60 for a coil spring setup and mine is a dana 60 for a leaf setup.
It's a dana 60 for a coil spring suspension. To determine the ratio, pull the cover and check the stamping on the ring gear. Just divide it out to get the ratio. In this case, 37/9 = 4.10
Taibo is offline   Reply With Quote
Old 07-31-2015, 08:18 PM   #4
Steven R
Ok thanks for the pointers and help. I power washed it today and font in two places a 60-3B or 60-38 and what looks like a casting number C34950. But have been all over the axle tubes and can't find any more stamped numbers.
pics here again thanks
I tried to get the pics right, I always take then the same way but they turn upside down sometimes. I rotated the file on my computer, will try it out hope this works.
Old 07-31-2015, 10:00 PM   #5
LockDoc
LockDoc's Avatar
Did you check on the front of the center section up by the pinion (pic in post #19 in the link I posted) If there isn't anything there then you will probably have to pull the rear cover to check the ratio, as taibo suggested.....
LockDoc
Leon
Old 07-31-2015, 10:57 PM   #6
Steven R
so i took the cover off and found this.
Old 07-31-2015, 11:31 PM   #7
LockDoc
LockDoc's Avatar
41-10 would be a 4.10:1 ratio.
LockDoc
Leon
Old 08-01-2015, 12:11 AM   #8
Steven R
right
thanks Locdoc
is there anything special about that ratio. I would guess it would be good for hwy use?
nevermind just realized I got it backwards 4.1:1 is good for acceleration but not hwy fuel mileage.
Old 08-01-2015, 12:37 AM   #9
SS Tim
SS Tim's Avatar
No not really, '72 Chevy C/20s used the Dana 5500 (Dana 60) in 3.54, 4.10 and 4.56:1 ratios depending on the model engine and transmission. It all depends on how much you are trying to move and how fast.
SS Tim is offline   Reply With Quote
Old 08-01-2015, 10:16 AM   #10
LockDoc
LockDoc's Avatar
right
thanks Locdoc
A 2004r, 700r4, or 5 speed Overdrive manual would be best for the 4.10:1 ratio on the highway.
LockDoc
Leon
Old 08-01-2015, 11:10 AM   #11
Steven R
ok thanks guys for the info i will keep this info on file.
Steven
