Old 09-08-2003, 08:36 AM   #1
dbenamati
dbenamati's Avatar
Flywheel cover question for I6 250
The cover has a hole on the bottom of the pan....is it supposed to be plugged like the oil pan?
Thanks, Dave
Dave Benamati
Hughesville, PA USA
dbenamati is offline   Reply With Quote
Old 09-08-2003, 09:00 AM   #2
crazy longhorn
Fabricate till you "puke"
No, the hole is open from the factory......I beleive its a drip hole for any oil that could get into the bellhousing area. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
