Old 07-31-2015, 12:00 PM   #1
jeffahart
jeffahart's Avatar
Wrapping wire harness - or not
I picked up an AAW classic update harness and am considering either wrapping the harness with the factory type non stick tape prior to install. Or, just using small zip ties every few inches and maybe wrapping what's accessible after install. And maybe not wrapping at all. I'm planning on getting some split loom for the engine bay.
I got a few days to ponder. I'm installing a new radio and speakers this weekend and I want that functioning in place before I do the complete rewire.
Any input, just curious what others have done.
White K20
jeffahart is offline   Reply With Quote
Old 07-31-2015, 01:00 PM   #2
cdowns
cdowns's Avatar
Re: Wrapping wire harness - or not
I've always been a big fan of a nicely wrapped wire harness, take the time and it looks good for many years to come
not a fan of the cheezey split plastic type of wire harness retainers
Old 07-31-2015, 01:34 PM   #3
MARKDTN
I will second that. Find correct harness tape and wrap it snug.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-31-2015, 01:56 PM   #4
MagmaJct
MagmaJct's Avatar
Don't think I've ever seen wire harness tape. How's it different than electrical tape?
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 07-31-2015, 02:38 PM   #5
jeffahart
jeffahart's Avatar
The harness tape is plastic non stick tape, but kind of sticks to itself a bit; and you tie off the ends. I just ordered two rolls.
Plus, what I thought was a non-ribbed split loom going across the firewall and core support is actually a purchasable part called "wiring harness mount rail", I just order this with the tape from brothers. So, I won't bother picking up any split loom.
I think I will spend the time to do a nice wrap. All the wires on the AAW are nicely labeled which started me leaning toward the zip tie idea. But then I've never had trouble tracing wires without labels, so no real loss... I don't think. There's that key word that always gets me .... think!
White K20
Old 07-31-2015, 03:59 PM   #6
leftybass209
leftybass209's Avatar
I did the wrap myself. 2 rolls is a lot! It's really an easy affair. I did the wrap, and also the crappy black covering stuff anywhere it couldn't be seen like the rear taillight harness and between the front fenders and inner fender wells for extra protection.
leftybass209 is offline   Reply With Quote
Old 07-31-2015, 04:15 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I use the OEM flat wrap. It's great stuff. Got it from Eastwood so long ago I can't remember what I paid. Start with a clove hitch then overlap the length of the wire run, then finish with a clove or half hitch. No sticky glue like E tape.
Pack Rats will eat it though. I find the old asphalt-based friction tape is much less toothesome to rodents, and I cover with that in runs that rats will gnaw.
Old 07-31-2015, 05:38 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
This... 100%.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-31-2015, 06:15 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Painless Performance makes a nice braided style wire loom that is split but looks great .
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-31-2015, 06:36 PM   #10
74baggedbug
I'm running that right now and I was really impressed with it.. Not cheesy looking and has a high melting point in case it gets close to the headers
74baggedbug is offline   Reply With Quote
Old 07-31-2015, 06:55 PM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
I'm running it on my junk too - it matches the black nylon braided hoses/fittings I used under the hood. I bought the 'fuel injection kit' and it was enough to cover everything from headlights to taillights and underhood.
Adam
Old 08-25-2015, 12:11 PM   #12
jeffahart
jeffahart's Avatar
I decided to wrap with the tape(OEM type loom tape from brothers). I used a complete AAW Classic update harness, it supplied everything except AC. I used one full roll of tape and a small amount of the second roll. I may have been a little wrap crazy in a few spots. I left a couple extra inches exposed at fire wall so I can easily yank a wire if needed. The only things I did not wrap were temp wire, brake wire, reverse wire to transmission and taillight wires after the bulk connector right before the bumper. I'm now very happy, with clean wiring that I know. All the old auxiliary camper wires and... who knows how many versions of trailer wires were the biggest mess.
White K20
Old 08-25-2015, 12:25 PM   #13
Taibo
Regards,
Mike
No adhesive.
Taibo is offline   Reply With Quote
