Old 07-31-2015, 03:29 PM   #1
BigSix
Is front half of transmission hump removable?
Before I start prying and permanently damage anything LOL I figured I would ask the experts...I have the transmission cover unbolted but I still need to remove the section in front of it. Looks like part is seam sealed and the other part doesn't have fasteners and I can't tell if it is spot welded? I can reweld the spot welds if that is all it is...any tips or tricks on its removal without trashing the piece or the floor?
BigSix is offline   Reply With Quote
Old 07-31-2015, 03:50 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Is front half of transmission hump removable?
It is spot welded to the firewall. The only way it's removable is by drilling out the spot welds.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-31-2015, 03:53 PM   #3
BigSix
Thank you. The panel is not at all rusty but it is so tough to see where it is welded! Hopefully hitting it with the cup wheel will make things shiny and easy to see. I have to drill from inside the cab so at least I have that going for me.
Old 07-31-2015, 04:24 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
That's how we find them! Clean it off a little and they will start presenting themselves.... there's always a couple that stay hidden and give you a surprise!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-31-2015, 11:28 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
the one that I did I found that it looked like the factory spot welded it right through the seam sealer, also the spots didn't really line up front to back, it was as if the spot welding tips were at an angle..
I use a heavy wire cup brush on the 4 1/2 in grinder and run over the seam, it will start to burn the paint/rust off, and leave a little bit in the divot where the spot is.
Old 07-31-2015, 11:45 PM   #6
padresag
some of the 60- 62 were removable at the firewall. perhaps it was only GMC with hydra-matic trans
ron
padresag is offline   Reply With Quote
Old 07-31-2015, 11:50 PM   #7
argonaut
argonaut's Avatar
I drilled the spot welds on mine then installed it woth 5/16" bolts. I tack welded the nuts on the engine side of the firewall so that I could easily remove both bottom and top sections of the hump.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 08-01-2015, 12:00 AM   #8
padresag
that is somewhat the same as what I just showed only mine was orig
ron
Old 08-01-2015, 12:20 AM   #9
argonaut
argonaut's Avatar
Yeah, I remember a 62 I had where the upper section and lower hump were both bolted in.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-01-2015, 12:35 AM   #10
jonzcustomshop
1961 crewcab
ron
that helps explain a 62-63 gmc cab I have! I always thought it was a big truck cab because of the bolt in front panel- (as far as I can tell all the 50 series and up trucks had the bolt in hump) -but it had custom trim, and did not have a few of the other signs of being a big truck.
Old 08-01-2015, 11:06 AM   #11
BigSix
Thanks guys. I am going to also bolt it in afterward because it might provide some needed access to the gigantic OD 5speed I have in there right now. I had to put the transmission in sideways and then straighten it after it gets through the tunnel!
Old 08-01-2015, 11:28 AM   #12
argonaut
argonaut's Avatar
Thats why I did it. It gives easy access to the bellhousing bolts and the back of the motor.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 08-01-2015, 12:36 PM   #13
padresag
easier and possibly less damaging to put those trans in from the bottom. did have one in mine behind a 4 cyl detroit
. standard hump was all that was required
ron
Old 08-01-2015, 03:16 PM   #14
BigSix
Got it off. Just a small tweak on the floorboard afterward and everything is good to go. Glad it all fit without cutting.
