07-31-2015, 08:42 PM | #1 |
Front driveshaft clearance with 4L60E
I haven't installed the 5.3/4L60E in the frame yet, but I know I'm going to have issues clearing the transmission pan corner. What have people been doing to fix this problem? Can I eliminate the CV joint and run U-joints on both ends? Any issues putting the CV joint at the diff side of the driveshaft?
Thanks |
08-01-2015, 11:19 PM | #2 |
Re: Front driveshaft clearance with 4L60E
I think mine is barely going to clear with the CV joint. If not I think I am going to just beat it in...I'll post pics of mine tomorrow once I get it installed.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
08-04-2015, 08:50 AM | #3 |
You could take out the cv but you will Be close on hitting the crossmember then. I've seen people run just a u joint at each end but have to chop out a v notch on the crossmember to make it have room. Without the cv in there you will also need a longer shaft to take up the extra room the cv gave the shaft.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
08-04-2015, 10:50 AM | #4 |
I only had about an 1/8" clearance so i notched the pan.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
08-05-2015, 08:06 AM | #5 |
08-05-2015, 02:26 PM | #6 |
The CV joint was bout an 1/8" from the pan when installed and i have a 4" lift. I worried that with suspension travel there was a chance the CV joint would contact the pan.
08-05-2015, 03:20 PM | #7 |
Thanks !
