Old 08-01-2015, 02:59 PM   #1
T and S
T and S's Avatar
Sway Bar Mounting
I am installing my sway bar I picked up on my 1966 C-10, but....
I thought (first mistake) the frame brackets mounted where the rivets are for the cross member under the rad., and then drilled 2 more holes. But with my brackets mounted there, my bar is into the springs maybe 1/2 to a full inch, so I know that can't be right. Their is a slotted hole in front of the rivet holes, maybe 4 inches or so and I am thinking that's where the front of the bracket should be mounted. If anyone would have a pic or suggestion it would be greatly appreciated, thanks in advance !!!
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 08-01-2015, 03:41 PM   #2
Uptown83
Re: Sway Bar Mounting
I just installed mine. Went fine. I removed the bottom rivets too and realized I didnt need to. I think you are going to have to post some pics.
Uptown83 is offline   Reply With Quote
Old 08-01-2015, 04:22 PM   #3
MisterC
MisterC's Avatar
Best tutorial on here:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 08-01-2015, 04:59 PM   #4
T and S
T and S's Avatar
excellent - thanks ! (I see my mistake, duh )
