Old 08-01-2015, 10:46 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
ok im going nuts here !
ok so here is the scenario i have grounded out everything i can the truck has great grounds but my damn gas gauge only works when it wants to lol by this i mean i bought a new sending unit put it in and it worked for like a week . now i sware some times its heat related but now you get in turn on the key into the on position and the needle stays on empty put gas in it dont change .. drive anyway say to like another city maybe 15 miles and shut it off .. hang with my friends at a car show a few hours go to leave and turn the key boom working gas gauge even floating while driving now working stop at the store on the way home and turn truck off ... come back in 10 mins start it up no gas gauge again ! im gonna rip my freaking hair out here guys lol what in the name of all that is holy could be doing this to me ? is it possible that the key ignition switch isent sending the signal to it ? ... all so here is somthing else when the needle is sitting on the E if you hit the dash hard then the needle will peg over to full even if not having a full tank turn off key still stuck on full hit dash again drops to E lol but the sending unit is new the gauge is new all wires have great grounds im lost help pleaase
WOLFMANmike is offline   Reply With Quote
Old 08-01-2015, 11:17 PM   #2
spookylynx
spookylynx's Avatar
Re: ok im going nuts here !
check the wire to the sending unit for nicks / cracks / lacerations maybe it got accidentally nicked during an install or during some work.
spookylynx is offline   Reply With Quote
Old 08-01-2015, 11:24 PM   #3
WOLFMANmike
yeah ive been there to already lol
Old 08-01-2015, 11:31 PM   #4
spookylynx
spookylynx's Avatar
do you have or could borrow another fuel gage to swap in? maybe the gauge itself is bad.
Old 08-01-2015, 11:54 PM   #5
jason999
I would start by moving the wire around to see if that has an effect on your fuel gauge. I'm sure you've already done that.
Next, I would take a multimeter with me on drives. When the gauge isn't work, check the ohms on the wire that goes to your fuse box. If the ohms look right, then plug the wire back in the fuse box. If the gauge still doesn't work, then the problem probably isn't your sending unit or wire.
Im guessing that you probably know how to use a multimeter, since you just installed a FSU. If not, let me know.
jason999 is offline   Reply With Quote
Old 08-02-2015, 02:57 AM   #6
WOLFMANmike
hey guys thanks your help i dont know how in gods name i missed it .. but some how i missed that the nuts that screw down the electrical L shaped fitting that the wires slide onto were loose .. i feel stupid now lol but ty for your help Happy Truckin
Old 08-02-2015, 07:46 AM   #7
jason999
I'm glad that you got it fixed.
I love a good easy fix. Actually, I need an easy fix! Lately, everything that I have been doing has been challenging with little or no results. I've messed with my steering column that wont lock in park for two days with no results. It looks like I will have to buy a new one.
