Is there a glass window mount channel available?
Dont know what to call this but my windows are mounted to a bracket to raise the windows and that part is fine, but the channel that the glass is mounted to is rusted through pretty bad. I was thinking to grind off the mounted spots of the channel portion and weld a new track for the glass to sit in. Also tried looking for a replacement part with the roller track but all that Ive seen are priced with the glass.
Registered Truck Offender
Re: Is there a glass window mount channel available?
If it's available,, I bet LMCtruck.com has it
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
What is the length of that channel, I may have some product to send you depending on length. I work for a company that has glass channel attachment material.
Each one is 22 inches long and the inner channel area that the glass fits into is around 8mm thick/wide. The sides of the channel are 1/2 inch tall. Thanks for checking!!
they make them for chevy cars from 55-57 and 59-60
you could put your tabs on the channel they make for the cars |
Moderator
![]() ![]() Join Date: Aug 2011
#8 | |
![]() Join Date: Jul 2010
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
![]() Join Date: Dec 2014
call Classic industries I just got 2 new glass assemblies from them and they are great I had the same issue as you and for me it was a pain trying to find those parts plus trying to mount them in the right location I just went ahead and payed 10O per window plus is all brand new part
My 1st build 1966 C10 Swb ..http://67-72chevytrucks.com/vboard/s...d.php?t=668147 |
![]() Join Date: Jan 2015
Thanks for the pointers and advice everyone. I found that same assembly on ebay a few days ago that cv65 pointed out. As soon as I get them In I'll get them assembled and see how it does
#12 | |
