Which gas tank is main tank?
My 78 GMC needs a new gas tank sending unit. When I look on rock auto's website they have a few different brands to choose. Most list if they are for drivers or passenger side except for the dorman ones, they list for either main or auxiliary tank. My questions are which tank is main and auxiliary tanks? Is there a certain brand of sending unit that is preferred; spectra premium, dorman, or other? Thanks for the help.
Posted via Mobile Device |
Re: Which gas tank is main tank?
Driver side is the main tank and passenger side is auxilliary.
Just here to tinker
Incorrect. I have had 5 square bodies with dual tanks and all main tanks were passenger side or RH tank.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
Passenger side has the shortest distance to fuel pump.
#5 | |
Gentleman Jim Driver
1973-1980 a single tank would have been on the passenger side. 1981-1987 single tank is on the drivers side. The optional second tank is the "auxiliary tank" by the sales and service documentation so that means the "main tank" matches what the factory installed when they only installed one.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds |
2X ElGracho. Up until 1980 the main fuel tank (correctly called the production tank) was located on the RH side. If the truck came with the dual tank option, it was equipped with another tank (called the auxiliary tank) which was located on the LH side.
In dual tank applications, the RH tank was the default tank. It would be the tank that supplied the fuel pump if no power was applied to the tank switching solenoid. Note the tank designations in the wiring diagram below. It is for a pre-1981 dual tank application: ![]() In 1981 the LH tank became the main/production tank and the switching circuitry was changed from a single wire system to a 5 wire system:
#7 | |
Primary tank was RH originally; became the LH tank after the front end refresh. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I was looking at 81-87 trucks when I answered that.
Thanks for all the reply's. I thought it was the right tank but just wanted to be sure. I ordered a dorman one from rock auto so now I should have a working gas gauge again. I went with the dorman one because it showed a lifetime warranty and all the others were only 1-3 years. I figure it's worth the extra cash not to have to drop the tank again.
| Bookmarks |
