Old 08-02-2015, 02:11 PM   #1
NastyBuzzard
NastyBuzzard's Avatar
2001 Silverado. No power to door lock switch or power mirrow switch. Help?
I can't get power to the door lock switch or the mirror switch. Any help? I have checked all the fuses I can find.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 08-02-2015, 10:24 PM   #2
NastyBuzzard
Re: 2001 Silverado. No power to door lock switch or power mirrow switch. Help?
Anyone? I don't want to just go buying relays and start throwing parts at it. It seems everything else that is supposed to have power has it. Is there something that these two share?
Old 08-16-2015, 07:37 PM   #3
hugger6933
I know you said you checked all the fuses, did you check the small amp fuse inside the left hand side of the dash? It is like a 3 or 5 amp if memory serves me. Jim
hugger6933 is offline   Reply With Quote
Old 08-16-2015, 09:11 PM   #4
NastyBuzzard
I switched out the entire fuse box from another used vehicle and that gave me power to door locks. Then I found a loose wire that was keeping power from the mirrors. Problem solved.
Now I just need to find a wiring diagram or something that will show me how the door shut sensor works.
Old 08-17-2015, 08:10 PM   #5
hugger6933
If your having a problem like the dome lamp staying on or the radio NOT shutting off when you open the door, you need to change out the door latch/lock actuator. Jim
Old 08-17-2015, 08:14 PM   #6
NastyBuzzard
Yeah that is the issue. I can switch off ignition and get out and radio keeps going...
However, the kicker to all this is that I am not using 99-06 doors. I am using the wiring harness from a 2001 to power my 87 with 91 doors. I already have the windows, locks and mirrors working and that is the last bit I have to figure out..
