Old 08-02-2015, 04:35 PM   #1
TKCR
TKCR's Avatar
What's this hose for?
I was replacing some dried out hoses today. When I replaced the bottom one and attached it to the hard line, the hard line felt like I knocked it loose. I got under the truck to see where this line went. It's not attached to anything, it's just an open end. Is it just a vent or something?
These 2 hoses are coming off the back of the intake manifold directly behind the carb. The bottom one goes down the firewall and underneath the chassis.
86 Chevy Silverado 2WD 305
Old 08-02-2015, 04:38 PM   #2
TKCR
TKCR's Avatar
Re: What's this hose for?
Here's the end that's under the truck
Old 08-02-2015, 05:32 PM   #3
77 Big 10
77 Big 10's Avatar
The only vacuum hard line that I can think of that goes under the truck in the vacuum line for the modulator for the trans. It will be on the passenger side of the trans, you should be able to see it from a rear view of the trans. It will be a small vacuum solenoid, like a round canister, with a nipple coming out of it. The hardline hooks to it with a piece of rubber hose.
77 Big 10 is offline   Reply With Quote
Old 08-02-2015, 06:04 PM   #4
TKCR
TKCR's Avatar
I will get under there again and look for the solenoid. What is this solenoid for?
It is currently on the passenger side, just not connected to anything.
Old 08-02-2015, 06:18 PM   #5
TKCR
TKCR's Avatar
I believe this is what you are talking about, and you can see the hard line next to it, unconnected. Also I found a coupler not hooked up, right above the solenoid, what's that and where does it go?
Old 08-02-2015, 06:34 PM   #6
77 Big 10
77 Big 10's Avatar
Could be for a th350 with a converter lock up. If you do not see a plug for it to plug into, it could be they changed the trans. The modulator helps the trans to shift. Just make sure the line is not leaking. Gook luck.
Old 08-02-2015, 06:45 PM   #7
TKCR
TKCR's Avatar
Thanks for your help. And I was wondering about the trans being changed out, cause I actually found a couple more couplers not hooked to anything, and I couldn't find the other connection where they would go.
Again, thanks for the help!
Old 08-02-2015, 06:56 PM   #8
77 Big 10
77 Big 10's Avatar
No worries.
Old 08-02-2015, 07:24 PM   #9
geezer#99
geezer#99's Avatar
When you get it hooked back up it should change how your truck shifts.
If not it is adjustable with that little screw inside. Turn it in cw if you want it to shift later. Turn it ccw for sooner shifts. Be aggressive in your adjustments. Try 3 turns at a time between tests.
