08-02-2015, 07:00 PM | #1 |
'63 Step-side -- Rear Wheel Width -- Tires
I'm trying to find out the widest tire that I can fit on my sons '63 step-side, with an original 12 bolt rearend.
Starting with the wheel... What width/backspacing/offset? Tires... Widest tire that will fit without any modifications? I.E. tubs/narrowing Thanks |
08-02-2015, 07:19 PM | #2 |
Re: '63 Step-side -- Rear Wheel Width -- Tires
Some angle iron, ready rod, nuts and a tape measure and measure it yourself.
Just like this. http://www.hotrod.com/how-to/wheels-...heels-fitment/ |
08-02-2015, 09:41 PM | #3 |
I would say a 275/60/15 is a good choice.15x8 with 4.5 bs. Measure for sure. Depending on rim some offsets aren't true.
Did have 31x10.5x15 on one. http://67-72chevytrucks.com/vboard/s...d.php?t=624351
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-05-2015, 08:54 PM | #4 |
I am running 275/60/15's on mine on a 7' wide slot 3.75 backspace. they are meaty id say 10" wide rubber and its a tight fit ...but fits ...see below
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
