Old 08-02-2015, 07:35 PM   #1
lanehicks76
5.7 vortec in 72 c10 issues
Hi guys. This is my first post, but I have been reading through this site for some time now. I recently bought a roller 72 c10 long bed. I had a 98 5.7 vortec from a truck that I put comp cams magnum 280, comp cams bee hive springs with required hardware, aluminum dual plane intake, holley 750 vacuum secondaries, hooker super comp 1 7/8 headers and jegs quite flow fuel pump. I installed cam straight up as per comps tech line. IM having trouble with backfiring through carb and exhaust. It acted like the valves were to tight, but I just ran them again to zero lash plus 1/4 turn. Also I have played with timing and all the same. Has anyone had this popping, backfiring issue. Thanks in advance . Oh yeah all parts are new and the long block was running strong before it was pulled.
lanehicks76 is offline   Reply With Quote
Old 08-02-2015, 07:44 PM   #2
geezer#99
geezer#99's Avatar
Re: 5.7 vortec in 72 c10 issues
What method did you use to run the valves?
The spin the pushrod or the wiggle the pushrod method.
It's likely you have a couple valves hanging open!
http://www.crankshaftcoalition.com/w...raulic_lifters
Old 08-02-2015, 08:55 PM   #3
lanehicks76
Hi there. I first set them on stand. Then I ran then with engine runnin .
Old 08-02-2015, 10:06 PM   #4
geezer#99
geezer#99's Avatar
What are you running for timing?
Have you proven your timing tab/balancer are accurate?
Old 08-03-2015, 01:41 AM   #5
lanehicks76
Yes it doesn't matter where timing is. Initial set at 10. Then total 38. Then moved dist. Around. No changes with backfiring
Old 08-03-2015, 06:57 AM   #6
cadillac_al
Running the valves with the engine running is pretty fool proof imo so they must be adjusted close enough. If you are positive that you don't have a spark plug wire crossed, then you must have a cam/lifter problem and will have to have a closer look. I crossed a couple plug wires a few years ago and it ran pretty decent until I got on the throttle and I got nice machine gun backfires. I ran it like that for a couple weeks because I was positive the wires were on correctly and an old dog like me couldn't make such a rookie mistake.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-03-2015, 07:14 AM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
x2 on the crossed wires, especially 5 and 7. could be a bit much on the total timing for a vortec
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-03-2015, 08:41 AM   #8
lanehicks76
I'm gonna change cap when I get to the shop if no good I will measure all valve travel. Thanks for all replies.
Old 08-03-2015, 09:19 AM   #9
geezer#99
geezer#99's Avatar
Look for coil bind too!
Vortec's don't like more than 32 degrees too!
Old 08-03-2015, 04:22 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
I know you said it's a '98 block, but is that magnum 280 a hyd flat tappet or hyd roller?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-03-2015, 06:49 PM   #11
cableguy0
Did you break in the cam properly and use plenty of assembly lube? Did you use a zinc additive during break in. If that cam is a flat tappet cam I really hope you didn't fire that engine up and let it idle while you attempted to adjust the valves. The first 20 minutes of a flat tappet cams life is the most important. If you didn't do proper break in I would suspect that you wiped the cam out.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
l31, vortec 5.7
