08-02-2015, 10:04 PM | #1 |
Cleaned Up My Garage Sale
Cleaned up my garage and I gathered all of the parts that have come off my truck. Most prices are shipped in the lower 48.
Rubber floor mat. In good shape, has one tear on passenger side. Pending to 46stude 4 blade clutchless fan and single grove water pump and crank pulley. $35 shipped for the fan, $20 shipped for each of the pulleys. In cab tank, I prefer not to ship - $80 Tank mounting hardware 4 rectangular washers, 6 original bolts and 1 replacement bolt - $15 shipped all metal 3 core chevelle radiator and modified mounts to fit C10. Core dimensions are identical to factory dimensions. $100 + shipping Custom auto sound dual voice coil dash speaker Sold Aftermarket radio trim plate. Held in place by radio cage $20 shipped Last edited by clemsonteg; 08-09-2015 at 09:23 PM. |
08-02-2015, 10:36 PM | #2 |
Re: Cleaned Up My Garage Sale
ill take the speaker
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
08-02-2015, 10:39 PM | #3 |
PayPal is clemsonteg@yahoo.com or I can pm you my address if you prefer to send check or money order. Please include the 3% for PayPal fees if using PayPal.
08-02-2015, 10:45 PM | #4 | |
08-02-2015, 11:02 PM | #5 |
08-03-2015, 08:01 AM | #6 |
that would be great thanks
08-03-2015, 08:47 AM | #7 |
08-03-2015, 03:06 PM | #8 |
Bump. Open to offers as well. Trying to make space for a new baby and fund the purchase of a Boyd Welding tank.
08-04-2015, 10:26 AM | #9 |
Is the mat for a 2wd low hump cab?
08-04-2015, 06:21 PM | #10 |
08-04-2015, 07:31 PM | #11 |
Alright, I thought it was, but my Dad always told me thinkin' wasn't my strong suit.
$60 shipped to 78382? |
08-04-2015, 07:54 PM | #12 | |
Edit: I'm not sure if it matters, but I pulled the rubber mat out again to clean and inspect it and I realized that I was looking at it upside down. The small tear is actually on the driver side. Just thought I would let you know in the spirit of full disclosure. Last edited by clemsonteg; 08-04-2015 at 08:12 PM. |
08-04-2015, 09:41 PM | #13 |
If other person passes on the mat I'll take it for $62 shipped to va 23666
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
08-04-2015, 10:16 PM | #14 | |
PM me your mailing address & I will get you a money order on its way in the morning. |
08-05-2015, 09:48 AM | #15 |
C/10 junkie
Can I get some better pics of the lower trim please
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
08-05-2015, 10:05 AM | #16 |
08-05-2015, 10:06 AM | #17 |
08-05-2015, 10:07 AM | #18 |
C/10 junkie
Primarily any damage or causes for concern. Also looking to see how aged it is
08-05-2015, 10:33 AM | #19 |
08-05-2015, 10:34 AM | #20 |
C/10 junkie
Ok. Pm sent
08-05-2015, 10:56 AM | #21 |
08-05-2015, 07:24 PM | #22 |
All PMs answered and parts updated.
08-05-2015, 10:10 PM | #23 |
If they're per GM specifications, any chance the OP can take measurements of the exposed holes for the moldings? I need to install uppers, lowers and tail moldings for a 71 Chevy short bed Custom Deluxe. I believe 69-72 are the same.
I have some idea from the books. The primary issue is the reference points GM used. I've read you deduct 5" from the assembly instructions by measuring from the rocker panel. My question is which part of the rocker panel? There's a flat ridge underneath, but I believe you measure from the lower body of the rocker panel instead.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-05-2015 at 11:00 PM. |
08-06-2015, 08:11 AM | #24 | |
08-06-2015, 08:30 AM | #25 |
Could I get a quote on the aux springs sent to 44805?
Mike Wilson |
