2006 1500 front shocks
It's time to replace the front shocks on my 2006 Silverado 1500 lt. The Haynes manual mentions a possibility that the truck could have a "suspension control system" ,and the shocks are different if so equipped. Before I order shocks I want to make sure I order the right ones. Haynes says "unlock and unplug the electrical connector from the top of the shock absorber" when removing those with a suspension control system. I see no connector but I really don't know if I'm looking in the right location. Anyone know if there is a code for this mysterious suspension control system? And maybe is there something on the dash to indicate if the truck has that system? The owners manual has nothing that would tell me if the truck has the system. Any info is appreciated.
#2 | |
Re: 2006 1500 front shocks
In regard to your question about an indicator on the dash. If there is one I think it would be located on the left of the steering wheel with a ''ride control, firm'' button. The code I do not know, sorry. Unfortunately I do not believe too many shock manufacturers will be producing shocks for the vehicles with electronic suspensions, only the non-elct. Luckily the fronts are the one's you want to replace, you should be able to use any replacement without issue regardless if you have the electronic suspension or not. Good luck! |
If it doesn't have any connectors to the shock, it is a regular shock. I've never seen one with the electric suspension[ trucks that is Tahoe and Suburban a different story] Jim
![]() Join Date: Feb 2011
I have an 06 Silverado with the "suspension control system" there is a button to the right of the heater controls. It looks like a tire bouncing over some bumps. Mine does have electrical connectors that go to the top of the front shocks.
Thanks Handmedown-that reply is sooo helpful. I do not see any electrical connector to the shocks but wanted more confirmation. There is no button that you describe to the right of my heater control. Based on your message I feel confident that I do not have the "suspension control system". Very helpful and thanks again.
| Bookmarks |
