Old 08-03-2015, 03:48 PM   #1
fourspeedwagon
fourspeedwagon's Avatar
Axle sits to the right?
Not sure how this happened or how to take care of it. Recently bought this and noticed this today.
fourspeedwagon is offline   Reply With Quote
Old 08-03-2015, 03:50 PM   #2
fourspeedwagon
Re: Axle sits to the right?
It's about an inch and a half total as measured from the frame rail to the wheel.
Old 08-03-2015, 05:31 PM   #3
cdowns
cdowns's Avatar
Get an adjustable panhard bar and dial it in
Old 08-03-2015, 06:33 PM   #4
fourspeedwagon
Ok thanks- so that's not an uncommon thing then. -- Had me worried there.
Thanks again
Old 08-03-2015, 06:46 PM   #5
michael bustamante
michael bustamante's Avatar
thats the front end isint it? is it a four wheel drive?
1967custom
michael bustamante is offline   Reply With Quote
Old 08-03-2015, 07:03 PM   #6
fourspeedwagon
Yes the front on a 4 whd
Old 08-04-2015, 09:18 AM   #7
SCOTI
SCOTI's Avatar
Front shouldn't be off that far.
Need to check body bushings, body to frame alignment, & then possibly check to make sure the frame is not tweaked.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-04-2015, 10:37 AM   #8
Keith Seymore
Keith Seymore's Avatar
If the cab is on the frame crooked then that can cause the front end sheet metal (the "doghouse") to shoot off to one side. One way to tell is if the gap between the fender and the bumper (which is attached directly to the frame) is different from side to side.
You might be able to true everything up by loosening the fenders and rad support to frame, and scooting it over.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-04-2015, 11:33 AM   #9
michael bustamante
id measure both sides from spindle to frame and see if theres a difference. like they are saying, the fenders might be a lil off.
1967custom
Old 08-04-2015, 01:22 PM   #10
fourspeedwagon
That's basically the measurement that I took. I went from the frame rail to the wheel mounting surface. It's about an inch and a half different. The sheet metal all fits good and doesn't appear to have ever been wrecked- original fenders etc too.
Old 08-05-2015, 06:16 PM   #11
SASROD
Did you check to make sure the wheels are the same width and backspacing?
SASROD is offline   Reply With Quote
