Old 08-03-2015, 04:22 PM   #1
Greasey Harley
Greasey Harley's Avatar
trying to find a rear only air bag kit
I have a 68 Chevy short wide, with coil rear suspension. I plan on doing a set of 2" drop spindles in the front.
It would be nice to get the rear down 4 to 5 inches and still be able to haul the dirt bikes or the Harley in the back, perhaps a small trailer too.
Air bags seem like just the thing. low when empty, pumped up when hauling and slammed for loading bikes (better load angle).
I assume I would need some fairly heavy bags, as I still plan to use it like a truck.
Also, I'm not sure about drive line geometry, shocks, shock placement, panhard bar etc.
I don't want to mess up my truck and not be able to haul heavy loads.
The truck will normally ride 4-5" lower in the rear when empty, and pump the air bags up taller and stiffer with a load
best options?
Greasey Harley is offline   Reply With Quote
Old 08-03-2015, 07:08 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: trying to find a rear only air bag kit
best options?
Shoot us an email and we can follow up and discuss your needs and recommend a system that will work best for your goals and budget!
Typically we would recommend the bags with mounting brackets, a shock relocation system, and a new trac bar that will work in harmony with the drop and travel the air system will provide.
You will also need a way to fill the air bags. You can go as simple as a schrader valve set up that you manually fill and deflate as needed, or an electric compressor and tank with valves to make it easier!
Sales@pbfab.com
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
