Old 08-03-2015, 06:57 PM   #1
bbj3316
water pump question
I have a small block GM motor in 1982 GMC pickup. I have changed the v-belt assembly to a serpentine system and I need a water pump with a heater hose outlet. What should I be looking for in terms of year models? Any help greatly appreciated.
bbj3316 is offline   Reply With Quote
Old 08-03-2015, 07:56 PM   #2
77 Big 10
77 Big 10's Avatar
Re: water pump question
Are you talking about this port? if so, my 77' stock WP had this port.
77 Big 10 is offline   Reply With Quote
Old 08-08-2015, 10:59 PM   #3
jetmech85
I looked at a 1994 3/4 ton 350 in a wrecking yard today. Had serpentine with a water pump that had the threaded port. I have seen earlier ones with holes not even machined in the pump. May take a trip to the store to search their stock.
jetmech85 is offline   Reply With Quote
Old 08-09-2015, 03:37 AM   #4
69heavychevy
69heavychevy's Avatar
early to mid 90's water pump is what you need. It will be reverse rotation and will have a port on the top.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
