Old 08-04-2015, 02:58 PM   #1
nxtruck
nxtruck's Avatar
71' C-10 vent window loose
Guys,
I'm normally hangin' out in the 60'-66' section, but I have a question about my son's 71' C10. Is it possible to tighten the nut on the bottom of the vent window assy. without removing the entire vent window? The reason I ask is because his LH vent window will blow partially closed while driving at highway speeds because of not enough spring tension to keep the vent window open. I noticed that there's a hole in the door,underneath the door panel, that allows some access to the bottom of the vent, but there appears to be a lock of some kind on the nut that's on the stud.
Can anyone shed any light on this?
Thanks!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 08-04-2015, 05:55 PM   #2
john
member #16
john's Avatar
Re: 71' C-10 vent window loose
Here's a link for vent window disassembly and shows the nut lock.
http://67-72chevytrucks.com/vboard/s...d.php?t=351471
john is offline   Reply With Quote
Old 08-04-2015, 10:41 PM   #3
nxtruck
nxtruck's Avatar
I appreciate that link, John! That picture of the lower pivot is what I needed to see. Between that link and borrowing a 67'-72' assembly manual from my buddy Fred, a regular here, I think I can get a handle on this situation.
Thanks again for the help!!
