Pine needles in cowl of '72 C20.
Hi,
I don't know if I am saying the area of the hood correctly, but in the pictures below you can see alot of pine needles gathered in the cowel panel area. Is there any easy way to get them out? I tried a shop vac, wouldn't fit in it. Any solutions, besides cutting down the pine tree? ![]() ![]()
Thanks, Emil 1972 Chevy C20 |
Re: Pine needles in cowl of '72 C20.
The cowl actually comes of really easy. You have to open the hood and doors. Then there's two bolts on each side and 5-10 screws on the top of cowl. You can get a kit that puts a grate under your cowl or just make your own for about 5 bucks. I used gutter screen because I was trying to keep leaves out, it would help with pine needles but something smaller might be better. May sound weird but I think it looks cool. I'll go snag you a pic.
#3 | |
Wow, a pic would be great, thanks! Are the bolts on the inside of the engine bay, where are the screws? On top of the cowl?
2 bolts each side
![]() Join Date: Jun 2012
Mine is the same as Andy's, window screen in there. Works perfect
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
One more thing, if you have pine needles visable from the top I guarentee you have pine needles where the vents are inside the cab, the vent doors are removable from the inside, then you can feed a vaccum hose down in the opening, the inside of the vent channel go's about 4-5 inches lower then the vent opening, with the vent doors removed you can get a small vaccum hose in there. There is actually a water drain hole in the bottom so if you fish around with a length of wire you should eventually find it, make sure you keep them clear if it rains where your at.
I bought pre made cowl guards that were made on a punch press in stead of the mesh screen that was posted, made with 2 different pieces it was about $40 if i remember correct.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Old member
This is the tool for removing the wiper arms. I posted back in 2011.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=452026
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
