Old 08-04-2015, 10:42 PM   #1
fitzgjf
Install TH350 in 62 C10
I have a TH350 that I am installing in a 62 C10. the torsion cross bar is right in the way of the tail shaft.
Is it ok to cut the cross member enough to allow clearance for tail shaft and then build some brackets to support the frame ?
fitzgjf is offline   Reply With Quote
Old 08-04-2015, 11:13 PM   #2
rcnutt
rcnutt's Avatar
Re: Install TH350 in 62 C10
I have a th400 in my 62...I won't be home untill tomorrow but I'll post a pic when I get home.
rcnutt is offline   Reply With Quote
Old 08-04-2015, 11:21 PM   #3
fitzgjf
cool thx
cant wait to see pictures.
Old 08-04-2015, 11:56 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps this thread will help:
http://67-72chevytrucks.com/vboard/s...gine+swap+1960
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-05-2015, 10:20 AM   #5
fitzgjf
Is it possible to just unbolt the torsion bar support and move it out of the way until I get the tranny in place ?
Old 08-05-2015, 10:21 AM   #6
fitzgjf
I can tilt it down and try and get the rear of the tail shaft resting on the torsion frame but i tmakes it difficult to keep the torque converter on.
doing by myself just trying to find a easier solution.
Old 08-05-2015, 10:33 AM   #7
fitzgjf
Did you cut out the torsion support to allow the tranny to lift right in ?
Cant tell from you post if you did or not.
Old 08-06-2015, 12:49 AM   #8
Captainfab
60-66 Nut
Are you trying to install the trans with the engine already in place? If so, I think you will need to either pull the engine, or drop the torsion bar crossmember. If you choose the crossmember, just be sure all tension from the torsion bars is off of the crossmember.
This is one of the reasons, I really don't like the '60-'62 frames.
Old 08-06-2015, 09:21 AM   #9
rcnutt
rcnutt's Avatar
My pics may not help....I have a 71 crossmember in my 62
Old 08-06-2015, 09:23 AM   #10
rcnutt
rcnutt's Avatar
[IMG][/IMG]
Old 08-06-2015, 09:25 AM   #11
rcnutt
rcnutt's Avatar
[IMG][/IMG]
Old 08-06-2015, 11:50 AM   #12
rudy62
rudy62's Avatar
I put in a th350 on my 62, here is a pic. The cross member was cut out and replaced with the trans mount.
rudy62 is offline   Reply With Quote
Old 08-06-2015, 12:00 PM   #13
62step
rudy62, that's a good picture. I'll use something like that for my 700r4
62step is offline   Reply With Quote
Old 08-06-2015, 03:45 PM   #14
DakotaKid
that wont do him any good, he is still using the Torsion Bar..
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 08-06-2015, 05:22 PM   #15
fitzgjf
thx for all the input fellas really appreciate it.
I just wrestled it in there without having to do anything to the cross member.
Was quite a task trying to hold torque converter on while lifting with a floor jack.
got it in tho but what a Pain !
Old 08-06-2015, 09:09 PM   #16
slepysal
slepysal's Avatar
Good job,can you snap a picture of the transmission installed?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
