Old 08-04-2015, 10:45 PM   #1
HOTFUN
HOTFUN's Avatar
LT1 Burb: factory air ?
I know you are a hvac specialist and your 65 is just spot on restoration so I got to ask you. I used old air products to replace my condensor, evaporator core, valve, new proten6 a6 replacement compressor. Everything fit and finished better than new. Had to use one oem hose clamp due to crimping tool too big to crimp collar. Otherwise all fitings replaced with o ring style or crimped collars, I am adding the binary switch to the dryer and cutout wires running back in old style loom to compressor. I planned for R-134 and would still like the look of both the oem r12 steel caps? Anyway to make this work? I figured I could leave alone the R=12 high side fitting. What are you using on your 65? Thanks . Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 08-05-2015, 09:09 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: LT1 Burb: factory air ?
Yes, just use 134A and leave the original fittings intact, they are easier to use anyways as you don't need an adaptor. I will probably be replacing my condenser as the 2 I have are in rough shape, my evap coil is decent so I will use it. Are you putting your X brace back in?
LT1 Burb is offline   Reply With Quote
Old 08-05-2015, 01:36 PM   #3
HOTFUN
HOTFUN's Avatar
Yeah it was riveted on the bottom and bolted at the top on the original ac factory installed ac core support. I thought I would use 1/4 inch steel button top alan head bolts that look like rivets on all four. The senior counter guy at NAPA that crimped my hose set said there was no way to not use the adapter fittings for R-134 but that makes me feel much better. My evap core was really super nice but then I decided why not have the whole system new when and clean when changing the system oil for the new compressor too. Thanks again LT1.
'72 GMC K2500 4x4
Old 08-05-2015, 05:58 PM   #4
LT1 Burb
LT1 Burb's Avatar
No worries, we never use those fittings for 134A in a commercial unit. We have units that hold 3500# of 134A and we use old style non auto fittings. I hate those automotive fittings, they are for dumb asses so they don't mix refrigerants. What did you use for an Evap coil and what was the condenser coil out of.
Old 08-05-2015, 08:13 PM   #5
HOTFUN
HOTFUN's Avatar
The evaporator core was copper tubing and was a direct drop in. I used their gas valve and my oem short barbed hp line fitting and new parker hose with #8 collar crimped at firewall end. The #12 size hose to compressor I used a new o ring straight fitting on the evaporator core and had to go with an original ac clamp on compressor. A little trying tightning the core end all mounted in place. I seriously about used a 90 fitting at the firewall to make that very close transition to the compressor fitting. But trying to duplicate factory it will work this way. The whole system cleaned up and sealed better than new with new gaskets everywhere. I'll post more pictures when I get the inner fender batter box in place.
'72 GMC K2500 4x4
Old 08-05-2015, 08:34 PM   #6
HOTFUN
HOTFUN's Avatar
On the condensor up front I bought their 60 to 66 ac condensor kit with binary switch and dryer lines. I wanted to hide line connections under battery box so I refabricated the high pressure line to hide mostly behind the grille surround panel. I also ditched the small line from kit with ports by running #8 hose directly to dryer fitting like oem. I'll use factory ports on compressor manifold and mounted hi/low pressure switch in dryer. This also hides behind grille surround panel. Made up cut sw wires and installed in old time cloth covering back to compressor. The condensor was a high volume aluminum in kit it bolted right up to existing shroud mounts. If it cools when done I will be 100 percent proud of this rebuild. I also lightly painted black all fittings lines condensor out front visible behind grille.
'72 GMC K2500 4x4
Old 08-06-2015, 01:49 AM   #7
LT1 Burb
LT1 Burb's Avatar
Sneak peek
Old 08-06-2015, 08:20 AM   #8
pimpston65
pimpston65's Avatar
Originally Posted by LT1 Burb View Post
Sneak peek
not to thread jump, but which silver did you use? cuz i couldnt find the perfect silver, so i went with one that has flake in it. or is yours fawn?
pimpston65 is offline   Reply With Quote
Old 08-06-2015, 08:28 AM   #9
corvettejim1968
corvettejim1968's Avatar
that's looking really good.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-06-2015, 09:14 AM   #10
LT1 Burb
LT1 Burb's Avatar
Its Fawn, same color as the dash.
