Old 08-04-2015, 11:05 PM   #1
6cylinderstepside
6cylinderstepside's Avatar
Alternate locations for transmisison cooler?
If memory serves, I thought people have run aftermarket transmission coolers in other places besides mated to the radiator fins. Any suggestions?
Thomas
- '79 Stepside inline 6
6cylinderstepside is offline   Reply With Quote
Old 08-05-2015, 02:05 AM   #2
andrewmp6
Re: Alternate locations for transmisison cooler?
Take make one that has a fan on it so you could really mount it anywhere it can get air flow.
andrewmp6 is offline   Reply With Quote
Old 08-05-2015, 09:14 AM   #3
Lokin4AReason
Lokin4AReason's Avatar
put it in the wheel well covered w/ a metal mesh ( protecting it from road debris )
noticed this in a hod rod mag some year(s) ago and thought that it was a pretty cool idea
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 08-05-2015, 09:43 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I bought a cab that had one mounted to the right floorboard
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-05-2015, 10:22 AM   #5
Liberty
Liberty's Avatar
FWIW I seem to remember mechanics weren't a huge fan on transmission coolers on our trucks.
Liberty is offline   Reply With Quote
Old 08-05-2015, 10:30 AM   #6
SCOTI
SCOTI's Avatar
Keeping the trans @ constant ideal temps makes sense for ANY vehicle.... including our trucks. I kept mine mounted in front of the radiator but I moved it as far out as possible while still between the core support limitations. This allows more direct/undisturbed airflow for the a/c condenser & radiator. I also did the same for the oil cooler.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2015, 10:40 AM   #7
77c10
77c10's Avatar
I bought one of those aluminum finned ones and have it mounted to the inside of the passenger side frame rail on my truck.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 08-06-2015, 12:32 AM   #8
6cylinderstepside
The inside of the frame rail one is what I remember, I wouldn't feel comfortable with it on a wheel well or floor pan, I live out in the country where there are many gravel roads. As far as putting them on trucks I don't see the difference from a car except that it might be used for more heavy duty purposes in which case it would be more beneficial. At any rate, in my case I am going from a manual transmission to an automatic so either I replace the good radiator with a new one with a cooler, or I use the aftermarket cooler that I have sitting on the shelf. I guess I'll just put it in front of the radiator as recommended. Just wanted to see if there were any secrets out there. I like the frame rail idea but since I already have the cooler I am limited with where it will fit and I think it will be too big there.
Thanks for the replies!
Thomas
Old 08-08-2015, 12:12 PM   #9
Axle
Axle's Avatar
I use a couple pieces of copper pipe (painted black) mounted vertically to the rad opening, and mounted the trans cooler to that.
The first transcooler I ran I used those through the rad straps, and ended up as most of you know with torn out radiator fins and rubbed through tubes, which prompted me to start mounting them to something solid. Had some scrap copper pipe on hand the first time around, and been using that since.
Alex.
Axle is offline   Reply With Quote
Old 08-08-2015, 12:44 PM   #10
Hiluxxulih
Hiluxxulih's Avatar
I just made two steel strips and bolted them to the core support and bolted to cooler to that , its pet peeve of mine mounting transmission coolers to the radiator fins .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 08-08-2015, 05:08 PM   #11
6cylinderstepside
That's some good ideas, I hated to mount it to the fins too. I'll do the same, thanks!
Thomas
Old 08-08-2015, 11:02 PM   #12
cadillac_al
I put a temp gauge on my K20 th350 twenty years ago and it never overheats. I guess I don't work it hard enough. I don't see how a six cylinder would overheat one. I would suggest a gauge first, to see if it is getting anywhere near hot.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-10-2015, 09:56 AM   #13
1970pelle
1970pelle's Avatar
I'm also not a big fan of attaching trans coolers directly to the radiator. I made a couple of very simple brackets and mounted mine way out front. Nothing revolutionary, then a couple of hole saw holes later plus grommets. And that is the OEM oil cooler just hanging out on the right. Done.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 08-10-2015, 10:30 AM   #14
gmachinz
88-91 Burbs w/towing package (that means most!) had a nice factory trans cooler-it mounts in the same spot on the 81-up truck/K5 radiator support also-I'd opt for a factory appearance.
gmachinz is offline   Reply With Quote
Old 08-14-2015, 01:32 AM   #15
6cylinderstepside
cadillac_al, I am going from a manual to an auto tranny so my radiator doesn't have a cooler so it is not a worry of overheating, but that I just need a regular cooler.
gmachinz, I am a big fan of keeping looking either original or "It looks like it could have been original". I'll hiy my yards looking for that!
Thomas
Old 08-14-2015, 04:42 AM   #16
1970pelle
1970pelle's Avatar
I'm more to the side of Function over originality. But if you look at what type work I do, A lot of thought goes into each and every decision before the final plan is finished.
Ken
― Ronald Reagan
