fuel gauge not working even after new pump
Ive already tried another cluster,a brand new fuel pump,full assembly(3 actually) n it still doesnt work. Anybody got any info on what else it could be. Its a 2005 silverado
"NO BAGS JUST PLAIN LOW" |
blood type; Retumbo
Re: fuel gauge not working even after new pump
look at data stream in PCM since it receives signal from sensor and sends info to cluster. If the fuel level reading is accurate check wiring between PCM and IPC. If it doesn't read in PCM check wiring between PCM and sensor
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
