Old 08-05-2015, 03:20 PM   #1
66bumpytruck
Updating your bench seat
Does anyone know what bench seats fit best in the 64-66 cabs? I have a chance to procure a 60-40 split bench out of an 88 Chevy Pu. I'm wondering if this will work without to much modification.
66bumpytruck is offline   Reply With Quote
Old 08-05-2015, 03:30 PM   #2
62step
Re: Updating your bench seat
http://67-72chevytrucks.com/vboard/s...d.php?t=341805
62step is offline   Reply With Quote
Old 08-05-2015, 05:05 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
The '88 style seat is a great choice for our trucks. Two of the mount bolts will line up and you'll have to drill the other two. The width is right, and the height is OK. I like to sit a little lower, so I chopped a couple of inches (lengthwise) out of my brackets.
I recommend the '88 seat if it's in good shape and the price is right.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-11-2015, 03:09 PM   #4
66bumpytruck
Well I ended up with the 60 40 split bench seat out of an 88 Chev pick up. Turning out to be a bit more complicated than I thought. Guess I needed the solid bench seat instead. Any ideas on how to deal with the way mods need to be made to deal with the contour of the low hump??
Old 08-11-2015, 04:42 PM   #5
chevyrestoguy
Can you post up pictures of what the issues are?
My build threads:
Old 08-11-2015, 05:48 PM   #6
66bumpytruck
At work right now and truck is at home. The seat requires 8 bolts to mount it so I need to drill 6 more. The contour or the low hump requires some shiming to make it sit correctly on the cab floor. I'll try to get some pics uploaded
Old 08-11-2015, 06:35 PM   #7
TopFuel1966
TopFuel1966's Avatar
This is a bench out of a '95 Chevy C-10. Perfect fit. The only mod I made was removing the headrests...........
TopFuel1966 is offline   Reply With Quote
