Old 08-05-2015, 04:29 PM   #1
72step
72step's Avatar
Best 7" Sealed Beam Headlight?
So I about finally have my truck on the road and it is running sweet. One thing I'm wondering is who makes the best regular halogen sealed beam? I mean I know they make all kinds of H4 type conversions and such but I just want the best light for the money with regular sealed beams. I know one of the headlights that's on there must be halogen and the other not because one side looks okay and the other not so bright. Any ideas?
72step is offline   Reply With Quote
Old 08-06-2015, 12:31 PM   #2
luvbowties
luvbowties's Avatar
Smile Re: Best 7" Sealed Beam Headlight?
Regardless of bulbs used--even if keeping stock ones--you need to by-pass the high amperage going thru your h/l switch. Following is a schematic if you wanna do it yourself; else you can count on his quality of product, already wired and shielded in a kit, including easy-to-mount relays.
Sam
>> http://www.persh.org/pickup/Headlights.htm <<
The guy furnishing this schematic, a member on here, has done it all and knows the ins and outs for DIY'ers and upgraders.
Sam
luvbowties is offline   Reply With Quote
Old 08-06-2015, 12:38 PM   #3
PGSigns
PGSigns's Avatar
I did the LMC full kit on my truck and it is a world of difference between the old and the new. Well worth the work going to a modern bulb.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-06-2015, 01:06 PM   #4
theastronaut
theastronaut's Avatar
GE H6024NH Nighthawk will be the best performing sealed beam. It's still only 35/65 watt though so they'll be weaker than decent H4's. They will be better than cheap or "pretty" H4's (LMC, eBay, no-name lights).
As posted above, a relay harness will make any light you choose brighter and take the load off of the original wiring and switch. You may have a bad ground or more voltage drop on one side causing the one headlight to be dimmer than the other.
If you do much driving at night, I would suggest a relay harness and GOOD (not chinese!) H4's like Cibie, Bosch, or Hella. You need headlights that will light up farther out than your brakes can stop so you have enough time to react and avoid anything in your lane.
Here are a couple shots of the beam pattern in my daily driver with Cibie H4's, a relay harness, and Hella 80/100 watt H4 bulbs.
Low beam:
High beam:
theastronaut is offline   Reply With Quote
Old 08-06-2015, 01:13 PM   #5
61K10
61K10's Avatar
just get a relay harness, plenty on e-bay or make your own. probably not much difference in regular halogen sealed beams.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-06-2015, 02:07 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I don't use the high beam lamps that often on my truck, so I still run sealed beams on those. I only avoid Philips brand sealed beams as I've owned some that were not painted on center and I could never get them aimed correctly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-06-2015, 05:02 PM   #7
argonaut
argonaut's Avatar
I installed Hella 7" H4 lamps in my 66. They retain the old school look but provide much brighter light and better pattern. Mine look great and I'm still running them through the headlight switch for now since I have all new wiring. I suppose they mifgt get a little better if run direct off of relays.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
