Old 08-05-2015, 07:57 PM   #1
AcampoDave
AcampoDave's Avatar
Door Lock Dilemma
Did the factory install the door handles so that the key would be inserted teeth up or down when the lock was in the vertical position? I wonder if my handles are mixed up with regard to left and right.
AcampoDave is offline   Reply With Quote
Old 08-05-2015, 08:27 PM   #2
scuderia
scuderia's Avatar
Re: Door Lock Dilemma
Teeth down... but they are interchangeable as mine had two different cylinders and only one key. Swapped them so I had a key to the drivers door.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 08-05-2015, 08:35 PM   #3
AcampoDave
AcampoDave's Avatar
Thanks. I guess I'll correct mine.
Old 08-06-2015, 01:42 PM   #4
61K10
61K10's Avatar
I have the org ones on both doors (came with the custom comfort option) one is teeth down and one is with teeth up. correct me if wrong, but don't they fit only one way in the handle?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-07-2015, 09:55 AM   #5
AcampoDave
AcampoDave's Avatar
Mine fit better one way over the other. However, it seemed as though I may have been able to force it to take the opposite position.
Old 08-07-2015, 04:19 PM   #6
1963c-10
1963c-10's Avatar
I have factory locks on both doors of my 63 and both face teeth down on mine.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-07-2015, 07:26 PM   #7
RANDY COX
RANDY COX's Avatar
I got lucky with mine the key works in both doors and glove box.... nowadays that's un heard of....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-07-2015, 11:10 PM   #8
AcampoDave
AcampoDave's Avatar
You got that right Randy.....but now my truck is a "one key for all locks" vehicle. I took all of them... doors, glovebox, and ignition down to my local lock guy and got them all keyed alike. And, I got the tumblers with teeth down.
Old 08-08-2015, 01:04 PM   #9
61K10
61K10's Avatar
my glove box also is the same key. so there's two.
1961 chevy K10
