Old 08-06-2015, 11:32 PM   #1
HumphreyMurdoch
HumphreyMurdoch's Avatar
Bellhousing crossmember the same 60-66? 60-72?
Hi guys, I've discovered the crossmember for my bell mounts is bent back on the passenger side. It's not real obvious laying under it, but I questioned it when doing my V8 swap and fought getting the mounts and all to line up.
Anyways, what years can I get another from? I don't have any pics handy, but mine is welded to the frame. I'm hoping one of the other years that either riveted or bolted in might work. It's a '62 and expecting to hear only ones from another 60-62 will fit, easily. fingers crossed.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 08-07-2015, 12:55 AM   #2
Captainfab
60-66 Nut
Re: Bellhousing crossmember the same 60-66? 60-72?
A bellhousing crossmember from a '63-'72 will be different than the one for a '60-'62. I'm afraid you are stuck with finding one for a '60-'62 and welding it in.
Old 08-07-2015, 07:11 AM   #3
HumphreyMurdoch
Ah what a bummer, nothing is easy with a '62. I'm guessing the frames are just too different to use one of the newer ones?
283 w/ a T5
