08-07-2015, 12:04 AM | #1 |
New questions regarding NV4500 swap & slave clearance
I was getting my parts rounded up for the swap and was about to order the Advanced Adapters bellhousing so I could run an external slave cylinder on the drivers side. The reason for this is because I was under the impression that the front driveline (4X4) would interfere with the slave cylinder on a stock height truck.
However I am being told now by someone else that I do not need the high $$$ bellhousing and a factory bellhousing with the slave on the passenger side will clear everything with no problems. His claim is that he has swapped 5 NV4500s into different trucks and used the factory bellhousing on each one with no problems. Can anyone confirm this? If I can use a factory bellhousing that would sure be cheaper on my pocket and could find one locally. Thanks in advance
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
08-07-2015, 02:23 AM | #2 |
Re: New questions regarding NV4500 swap & slave clearance
My factory bellhousing has the slave cylinder on the drivers side, however it is two wheel drive (1985).
08-07-2015, 10:04 AM | #3 |
Post Whore
Look at it this way....chevy built a gazillion 5spd 4wd trucks over the years. Not sure what year truck you are working on but on a square all your 4wd driveline is on the passenger side and your clutch controls are on drivers side..
08-07-2015, 10:11 AM | #4 | |
Follow me now?
08-07-2015, 01:07 PM | #5 |
Would a hydraulic throwout bearing be something that would help?
08-07-2015, 01:09 PM | #6 |
I'm sure an internal slave cylinder would solve my issue but I wanted to keep with an external slave cylinder for the ease of replacing it when the need arises
08-07-2015, 09:34 PM | #7 |
I saw recently somebody redrilled the nv4500 so the sm465 bellhousing worked on it. thats a cheap way to do it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-07-2015, 10:08 PM | #8 |
Post Whore
chevy 3+3..I have a nv4500 in my truck and although it isn't 4wd my clutch controls are on drivers side...that's the way I bought it..and yeah I know the difference between a sm465 and a nv4500..
08-07-2015, 10:21 PM | #9 |
Maybe someone redrilled your nv4500 to fit the sm465 bellhousing or yours is running an aftermarket bellhousing
08-07-2015, 10:25 PM | #10 |
I appreciate everyone's comments and trying to help but I'm really needing to know if a factory nv4500 bellhousing with passenger side clutch slave will clear the front driveshaft.
08-07-2015, 11:27 PM | #11 |
I know the pieces fit
Search on username DirtyLarry, he's swapped NV4500's into both of his squares and use them off-road regularly. He uses factory parts wherever possible, it's a great reference thread on how to do it with the max number of factory parts if that's the route you want to go.
08-09-2015, 05:37 PM | #12 |
Yes, it can be done.
