Old 08-07-2015, 01:18 AM   #1
dwalt14
wiring issue with gauges
Any ls guys running dakota digital gauges? Put an ls1 in and my oil and water pressure work but my tach speedo and fuel arent. I tried to put them on all the settings with no luck
dwalt14 is offline   Reply With Quote
Old 08-07-2015, 10:19 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: wiring issue with gauges
I would contact DD tech..they helped me thru some issues I had with my speedo drive controller.
mongocanfly is online now   Reply With Quote
Old 08-07-2015, 02:06 PM   #3
Hart_Rod
Hart_Rod's Avatar
tach and speedo sound like a signal problem. Either none, or incorrect. Speedo has to be calibrated, tach needs to be on 4 cylinder setting usually. What engine and computer are you running?
Hart_Rod is offline   Reply With Quote
Old 08-07-2015, 04:24 PM   #4
dwalt14
I'm running an ls1 from 04 gto with the same computer. Had to build the harness though
Old 08-07-2015, 04:24 PM   #5
dwalt14
Motor and computer are from 04 gto.
Old 08-07-2015, 09:19 PM   #6
GMC-YA68
GMC-YA68's Avatar
DD makes a PCM interface that plugs into your OBDII and reads both of those from the computer. It's $100. Mine works great. The only thing that isn't working on mine at the moment is the fuel.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
