Old 08-07-2015, 07:34 AM   #1
Hennyhog
Uh oh..tick tick tick tick...please help.
Hello All,
Finally got my 71' C-10 running strong and noticed about a week ago after getting on it merging into traffic a slight tick while at idle and low RPM's. I only drive the truck a few times per week and the next time I drove it I said to myself " Am I hearing things? Was this noise here before? Am I being overly worried about nothing?"
Well yesterday after work I just wanted to start it after not driving since Sunday and upon lifting the hood, I could hear a "tick tick tick..tick tick...tick tick tick..tick tick" Coming from the front of the drivers side valve cover. I looked around to see if a tie wrap or a the wrapper radiator hose was lightly touching the alternator or fan blade and that wasn't the case. As I manually opened the throttle to increase RPM's you couldn't hear it nearly as well or at all. Oil level is right on too BTW.
My guess it's a noise lifter or rocker arm? I do not want to drive it now until I get some advice on this matter and listen to what you guys have to say. Any and all advice will be greatly appreciated!
Thanks,
Henny
Hennyhog is offline   Reply With Quote
Old 08-07-2015, 08:56 AM   #2
jabborabbo
jabborabbo's Avatar
Re: Uh oh..tick tick tick tick...please help.
Does the tick frequency increase as you increase the rpms?
jabborabbo is offline   Reply With Quote
Old 08-07-2015, 09:26 AM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Sometimes it can be pretty hard to tell between a valve issue and an exhaust leak. Id check to make sure the manifolds arent leaking before jumping straight to the valvetrain.
Tyler
57taskforce is offline   Reply With Quote
Old 08-07-2015, 10:51 AM   #4
Coley
Coley's Avatar
This might be a loose rocker. Simply take off the valve cover and manually wiggle all of the rockers (engine off!...lol) and I'll bet you'll find your culprit....and maybe check both valve trains/both sides while you are at it.
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 08-07-2015, 10:58 AM   #5
hugger6933
Sounds like a loose rocker. When you have the cover off look at all of the studs to make double sure they are the same length. [What I'm saying here is that one of the studs may be working loose] But I sure don't mean to scare you it is a remote[very ]possibility.
hugger6933 is offline   Reply With Quote
Old 08-07-2015, 11:09 AM   #6
cdowns
cdowns's Avatar
I'd go at the exhaust manifolds first before friggin with the valves . For the valves i'd try using marvel mystery oil first before anything
Old 08-07-2015, 11:39 AM   #7
chopnchaneled
chopnchaneled's Avatar
My tick turned out to be one of the spark plug wires had burned thur on the exhaust manifold.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 08-07-2015, 12:36 PM   #8
Xeen
Xeen's Avatar
Yep that will do it, time to go buy a bunch of wire separators and go to town on it and get all the wires separated and routed properly.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-07-2015, 01:39 PM   #9
englands 71
englands 71's Avatar
your tick could be an exhaust leak. My 70 nova had blown a gasket under the car where the header bolts to the exhaust.
could be lifter.
It could be a spark plug finding another ground. Turn the lights off in the garage tonight and see if you see a spark on that side in the dark.
Did you adjust or move the distributor ? Is the distributor nut tight ?
englands 71 is offline   Reply With Quote
Old 08-10-2015, 06:49 AM   #10
Hennyhog
Thank you all for the input! Luckily it was just an exhaust manifold leak. Front two bolts on header were pretty loose on drivers side so I tightened all of them. Noise isn't 100% gone but considerably quieter.....need to get some new header gaskets.
