Harness plug near booster
I believe the round harness connector by the booster is just for the front end lights? Is there a replacement source for the connector on the firewall? I may just eliminate it and run new wires through a grommet unless someone thinks there is a reason to keep that connector? My goal is to eliminate all the holes in the firewall by welding them up and run everything through as few holes as possible.
#2 | |
![]() Join Date: Aug 2013
Re: Harness plug near booster
At the vary least you will need a hole there for the blinker wires.
Ok thats fine...can I find a replacement for that part?
On the 61's, the top connector goes up to the hood for the turn lights and parking lamps. The bottom harness has the alternator (12+) and the headlights. Without looking at the diagram, I forget what was in the rest of that connector.
You very easily could delete both plugs and weld the holes and rerout the wires where they are not seen. On the hood connector, you could run this through the firewall into the small area of the wheel well and then out the outside of the wheel well, routing the wires along the hood hinge. Done well, You probably would hardly even see those wires... Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
