Old 08-07-2015, 09:03 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
speedo / odometer
I have a 56 truck that the speedometer works but the odometer does not. Any ideas on how to fix? I thought they were tied togather and both would or would not work. Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 08-08-2015, 08:35 AM   #2
Old Crow
Old Crow's Avatar
Re: speedo / odometer
The speedo is driven by a cable that spins a magnet, while the odo is gear driven off the same cable. Since the speedo works, you know the cable is good.
My guess would be a stripped gear on the odometer.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 08-08-2015, 10:52 AM   #3
Russell Ashley
Russell Ashley's Avatar
I have the same problem, my odometer has stopped too. Mine stopped when it got to a place where several of the digits should have rolled up. Unfortunately the only way to fix it is to remove the cluster, remove the speedometer, and repair or replace it.
Russell Ashley is offline   Reply With Quote
Old 08-08-2015, 03:18 PM   #4
_Ogre
_Ogre's Avatar
unfortunately i've had my speedo cluster apart many times over the past year
no magic in there, other than the speedo itself
the odometer is a couple of gears and the numbered head
there are a couple of ways the odometer could stop working without any damage to the gears
there is a clip that holds the long brass gear in that is most likely your problem
take it apart and look at what has slipped out of place
i reset the odometer to the actual miles on my truk since the rebuild
there is also a member on here TBONE1964 that does speedo repair
i sent a speedo head to him for calibration
he lives in juntion city oregon and may be close to you
but... other than calibration the speedo/odometer is pretty simple
i thought i was being smart when i bought a new one when i rebuilt truk
cheap offshore junk is all there is available, i went thru 4 different new speedos before a member sent me an old head and i had it calibrated
shop air compressor timer
Old 08-09-2015, 01:40 PM   #5
SCHRUMGMC
SCHRUMGMC's Avatar
Heck my speedometer doesn't work at all and the odometer doesn't either
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 08-10-2015, 05:50 AM   #6
Old Crow
Old Crow's Avatar
In that case I'd be checking out the cable.
Old Crow
Old 08-10-2015, 11:53 AM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
I have a brand new one in there
1971 GMC Sierra
1959 GMC 100
