Old 08-07-2015, 09:19 PM   #1
blue22bomber
Fuel Tanks
So recently took apart my 79 c10 and am in the process of making it a k20 by setting the 79 body on a 87 frame and adding dual tanks. I have everything except one fuel sender and the fuel selector valve. I dont know what selector valve to use? And i am keeping it carbureted if that helps
thanks
ps If there's anything I'm missing please let me know. This is the only thing keeping me from putting the cab on.
blue22bomber is offline   Reply With Quote
Old 08-07-2015, 10:29 PM   #2
wilkin250r
wilkin250r's Avatar
Re: Fuel Tanks
The 79 used a single-wire switching valve, and it's nearly impossible to find. You might get lucky at a junkyard, but you won't find a new one, even aftermarket.
If you're starting basically from scratch, and looking at routing wires and adding the tank selector switch inside the cab, you're probably MUCH better off upgrading to the 6-wire motorized valve.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 08-08-2015, 01:40 AM   #3
blue22bomber
Re: Fuel Tanks
Do you know where i can get a motorized selector valve at?
Old 08-08-2015, 11:35 AM   #4
rich weyand
rich weyand's Avatar
Re: Fuel Tanks
Amazon.com: Pollak 42-300P 6 Port Fuel Selector... Amazon.com: Pollak 42-300P 6 Port Fuel Selector...
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
