![]() Join Date: Nov 2013
stumped
the driver rear wheel is freezing. Seems to freeze when I back up and then unfreeze sporadically and also freezes sporadically. Last year replaced master cylinder and both rear wheel cylinders and everything was fine. Just replaced the rear shoes and drums and frozen solid again (still on jack) the wheel cylinders are not sticking and the emergency brake cable is not binding. the axle spins freely when the hub is off.
Re: stumped
ho70
Make sure the self adjuster is on the correct side Take a picture with the Drum off and post it up Something might be reversed
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
Re: stumped
bad soft line
Re: stumped
If the adjuster is in backwards the more you drive the tighter it will get.
Re: stumped
There is also supposed to be a wave washer in between the parking brake lever and the brake shoe lever and if it isn't there it will cause the assembly to stick and or bind causing the issue you describe, if you need one head to Ace hardware they carry them in the special fasteners bins in the nuts and bolt section.
Though the wave washer may be a contributing factor it sounds to me like you have the mechanism improperly assembled. Last edited by Xeen; 08-08-2015 at 09:49 AM. |
Re: stumped
No wave washer was there when I reassembled the brakes... I will add he brakes worked fine from the last work (wheel cylinder replace) last year until now
here is a pic just before I redid the brakes last night, can't post new pic as I am not home right now to take new pic also, if it was a soft line plugged, the wheel cylinder plungers would be out. The passenger side shoes and the driver shoes are same width apart at bottom and top |
Re: stumped
passenger side
Re: stumped
From what I can tell you have it assembled correctly, pull it back apart and install the wave washer and it should work as intended.
The wave washer is very important, you must have it. You need to replace both of those adjusters they are trashed. |
Re: stumped
Btw some people don't know this so I thought I would mention it.
Those drum brakes are self adjusting and how they work is you put it in reverse and back up 10 feet then hit the brakes and it will self adjust, do this a few times and they will be fully adjusted. |
Re: stumped
good point, I take it for granted everyone knows that because I'm getting old...I'm headed to Galena Kansas for family reunion end of month for couple weeks..dad was born there in 1910, i'm thinking of touring the Leavenworth Fed Prison...any other attractions I might want to check out in Kansas there Xeen?
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
#11 | |
Re: stumped
![]() Seriously though I can't imagine a much more boring state there just isn't any exciting attractions like the mountain ranges in Colorado or the Grand canyon in Arizona or the Caves in Missouri, there is just nothing and more nothing. |
Shortbed club member
Re: stumped
I had a similar issue after replacing a wheel cylinder.
Turns out brake fluid got on the brake shoe from the leaking cylinder and caused the lock up. Replace the shoes and clean the drums and you should be good to go.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
#13 |
Re: stumped
well.......I had cleaned all parts with brake cleaner and no leaking fluid. Replaced the shoes on one side and new drum won't fit. Shoes all the way in and cylinder not out at all as top shoes are against pin. installed old drum on new shoes and so far so good. Truck was running crappy and bogging at 50 mph-fyi-removed check valve in carb filter and voila no more bogging. Maybe drive it further than around the block for once-thanks for the help, ps still can't find any wave washers, called 9 places-no ace hardware here. Brother in parts at ford, can't get them either
#14 |
Re: stumped
Someone around has to be able to get wave washers because there are lots of machines that have to have them to operate properly, do you have a fastener specialty store or a machinery service or supplier around anywhere?
#15 |
Re: stumped
#16 |
Re: stumped
if you clean between the 2 surfaces you should be able to get away with antisieze for a while the heat wont bother it and it wont wash away easily and will let the 2 slide easy enough for the short distance that needs
#17 |
Re: stumped
temporary fix till you can find the right parts and get them installed
#18 |
laying low
![]() Join Date: Mar 2001
Re: stumped
This sometimes happens when two secondary shoes are put on instead of 1 primary and 1secondary shoe. ?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#19 |
Re: stumped
damn, forgot about this. Thanks, i was thinking there is no hole in the back of the hub to adjust, until i just read your message and remember this.
#20 |
![]() Join Date: Mar 2005
Re: stumped
One way to find out if it is a hydraulic or mechanical problem is when the wheel is locked up is to loosen the bleeder valve. If the brakes release then you have pressure remaining keeping the brakes engaged
Good luck
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
