Old 08-07-2015, 11:07 PM   #1
dwreck812
Headlight and taillight problems
So my problem is when I turn my headlights on my taillights don't work when I turn on my running lights my brake lights work but without my running lights on my taillights don't work any solutions
dwreck812 is offline   Reply With Quote
Old 08-07-2015, 11:48 PM   #2
swamp rat
swamp rat's Avatar
Re: Headlight and taillight problems
"So my problem is when I turn my headlights on my taillights don't work."
"When I turn on my running lights my brake lights work"
"But without my running lights on my taillights don't work"
Do your turn signals work with the lights off or in these 3 conditions??
First thing check for grounds at all the light fixtures, check that the bed is grounded to the frame, the body is grounded to the engine, the engine is grounded to the battery.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-09-2015, 11:53 PM   #3
airdale94
airdale94's Avatar
Yes, also check all your bulbs. They can do crazy things if broken, or installed backwards.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 08-10-2015, 08:35 AM   #4
dwreck812
Well now all my lights work I'm guessing there could be a lose connection or something
