Pic Of my 65 Chevy frame
Here is a pic of my 65 chevy Frame with all the 72 Blazer Front and Rear 4x4 axles and brackets bolted in place making my 2wd into a 4x4
Re: Pic Of my 65 Chevy frame
Did you leave the 2wd crossmember in place?
Yes I did and added bump stops to the bottom , also to retain my engine mounting brackets.
Picture is very grainy for me. Hard to see what's going on.
Posted via Mobile Device |
little better pic
Is the crossmember going to interfere with the front driveshaft or anything else when the suspension cycles?
60-66 Nut
![]() ![]() Join Date: Mar 2007
You're going to have a problem with the front differential hitting the 2wd suspension crossmember. Why not just use the engine crossmember from the Blazer?
I don't have the crossmember from the 72 blazer. will any other year blazer crossmember work if you all know? Thanks
60-66 Nut
It doesn't have to be from just a Blazer......we're working on Chevy's here not F*&ds. All '67-'72 K5,K10, K20 and K30 engine crossmembers are the same. You could also use the engine crossmember from a '73-'87 K5, K10, K20 or K30, but some modification will be needed.
Thanks Capt , Are they bolted in or Riveted in ?
1961 crewcab
that looks like the complete unit
you could also source one out of a 73-87, I used one in my sub, had to cut the mounts down just a little , which you can see in the pic
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
mine has a 4 inch lift, and I don't plan on using it for anything other than winter transport, so I didn't feel that it would ever move enough to hit the bumpstop.
however I did save all the bumpstops off the 87 , there was one that the diff would hit, and another 2 for the spring pads...
