transmission auto indicator dash
My indicator does not move when using lever. I see strings that should move it, what do this attach to?
79 Chevy 2wd BIG10 350 TH400 |
Re: transmission auto indicator dash
Mine had the same problem, the cable (string) goes around a guide, and mine snapped off. I used a small piece of tubing and a small washer, and recreated the guide. Washer is a little bit bigger than the tubing, so the washer retains the cable and it rides on the tubing.
Robert Olson Transport
![]() Join Date: Oct 2002
the string attaches to a clip on the steering column where the shifter is when you ull the shifter down or push it up it allows the indicator to adjust to the corresponding setting
Here's the indicator. The little wire hooks on the RHS of the orange slider as shown. The right side of this piece contains a roller. The wire goes over the roller and connects with a screw to the side of the column.
![]() You can buy just the wire separately. The fitting is the end that screws to the column. http://www.classicparts.com/1973-83-...ctinfo/91-472/
Rich Weyand 1978 K10 RCSB DD. |
Okay thanks guys I think I am just going to use a small piece of wire to connect to column. The string is connected to the indicator but the string to the column looks like it broke. I am really getting slow the older I get. It took me 4 hours just to change the passenger fender in my truck and some bolts went in crocked or not at all. I was hoping to get to the interior of truck but time got away from me. I needed a beer break after the fender
It's ok. Some of the bolts in the fender probably went in crooked when it was new.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
A craft store like hobby lobby, in the jewelry making section, will have the small dia. cable and crimps, you could make your own. Good Luck
I made my own out of fine aircraft wire rope and crimps, and it broke in about a year. So I bought the replacement part and it has been fine since, 2+ years.
