Engine problems after body shop?
I just got my truck back from the body shop. Now it misfires quite a lot, mainly after stopping and in 1st gear. Its a really muffled "pufpufpuf".Eevery once in a while I hear a slap noise and It'll almost die. Suggestions? its got new plugs and wires from last year.
Re: Engine problems after body shop?
this also happens more when the engine is cold and it doesn't completely stop when its warmed up
Carb or FI? Mine will puff back through the carb slightly sometimes. I think I need to fine tune the choke settings and possibly tweek the timing a degree or two. Of course fuel injection would not have choke issues.
Could the air filter be full of bodyshop dust?
depends on how long it was at the shop. Might be bad gas.
At the body shop.
New plugs, probably loaded up from idling about
" That didnt make it any newer " " Dont antique the equipment " |
If they did anything around the engine area, they might have knocked a few plug wires loose and installed them back in the wrong order. Or pulled loose a vacuum hose or two.
