Old 09-08-2003, 08:01 PM   #1
Russell
Professional Grade
Russell's Avatar
What all is invloved in removing a steering column?
Hey everyone!
Not sure if any of you remember, but I did a welding hack job on my column, and it finally broke, I located a solid new one, and I wanna know what it takes to pull a column. Is it just a matter of disconnecting the electronics, undoing the bolts then just pulling it out, or is there anything else that I need to know about? Any tutorials with pictures would be useful...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-08-2003, 08:25 PM   #2
cochino12
It followed me home?
cochino12's Avatar
You've got it, thats all there is to it. You might want to yank the wheel off for some more room though. It's very simple
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-08-2003, 08:26 PM   #3
Russell
Professional Grade
Russell's Avatar
Oh excellent
Old 09-08-2003, 10:42 PM   #4
Russell
Professional Grade
Russell's Avatar
Uhh, I took out the four bolts that are just under my bezel, and also four or five bolts down by the firewall, no matter how hard I pull on the thing, it doesn't move, and I am afraid that the steering wheel is about to break off (yes, it is that bad...)
What am I missing? Is there anything that I have to do in the engine compartment?
Old 09-08-2003, 11:06 PM   #5
cochino12
cochino12's Avatar
yes, follow the column all the way down and there are four more bolts and if you have a automatic you need to disconnect the shifter. Make sure you have all the bolts out of the gasket thing in the firewall
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 09-09-2003, 12:01 AM   #6
Russell
Professional Grade
Russell's Avatar
Ah, found the problem, there is a bolt that goes through the column sideways attaching it to the control arm in the engine compartment, took it out and the whole thing slid right out
off to the wreckers I go!
