Old 08-09-2015, 06:44 PM   #1
74project
complete wire harness for truck and motor?
Does anyone know if a company out there makes a wire harness that also includes an ls engine swap?
74project is offline   Reply With Quote
Old 08-09-2015, 09:27 PM   #2
OneOffStroker
Re: complete wire harness for truck and motor?
Nope. Wiring harnesses are basically considered 'Chassis' harnesses, and the 'Engine' harness is totally separate. Get an EZ or Painless harness for everything in the truck, and use a stock LS harness that you will need to mildly modify. There is a lot of info on www.lt1swap.com for the necessary modifications to the LS harness to make it an easy enough hook up.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 08-09-2015, 11:12 PM   #3
74project
Thank you.
